Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I think those are ****hawks and not a 3DR Pixhawk, correct? It seems that *hawk manufacturers do not know how to properly power down LS303D or they are using a cloned one with slightly diffferent specs with the original pixhawk schematics. I suggest when you short the power input, short it for full 4-5 seconds as the goal is to discharge capacitors behind all the voltage regulators and unlike ESC caps those do not fully discharge with a momentary short.
Sorry if this is repetitive (artifact of using a single thread for all feedback regarding this release vs. something threaded like APM 3.3 Forum I wish we could migrate to):
I have found mixed reports of being able to connect the RSSI port on a FrSky receiver such as X8R to the sbus port on a Pixhawk, then setting RSSI_PIN to 103 to get RSSI input. However, other reports suggest this must be connected elsewhere in order for it to work with OSD, and yet others suggest PWM RSSI input has been implemented but will only be merged "in a future release". Is 3.3 that future release? I tried it and got odd values in the 90% range seemingly regardless of where I put the radio, and even if the radio was off, so I suspect either it is not implemented.
I have seen reports of others doing this without a filter to convert the PWM to analog, however, so I thought I would ask. Can RSSI out on FrSky receiver report PWM RSSI to Pixhawk, and can it be viewable both in Mission Planner and OSD? Thanks all.
I believe this is another scenario of "GPS-correction overriding pilot input". In my case I fly with rc8. My copter triggers battery failsafe LAND mode. GPS quality is very bad. It leans forward by itself regardless of my full-pitch-back input. I am confused at that time as LAND mode should accept my pilot X-Y correction but it doesn't. This case is discussed here and is not arrive to a solution yet.
Wes's proposal is stop listening to GPS when (flight_mode == loiter) and (throttle_input == min)
Mine proposal is stop listening to GPS when (flight_mode == land) and ( (pitch_input != centre) || (roll_input != centre) )
I think in general, autopilot should stop listening to GPS correction when there are input from pilot. Give pilot control the highest priority. Maybe position-hold mode is already doing this?
I'm using it with  the  RSSI filter as per wiki.
I tested AC 3.3 RC10. This is a very stable release.
And I wanted to draw attention to the following:
1. Upload the firmware to Pixhawk AC 3.3 RC10 will be better if the first from AC 3.3 RC 9 down to AC 3.2.1, and then up to the AC 3.3 RC10
2. Then need to check all the major parameters.
 And they are need to be rewritten.
2. I do not use the automatic tuning. Better to use the manual settings for test flights.
3. Very important buttons 'Calibrate Level" It is advisable to use prior to each flight.
4. I'd like to ask to make the possibility of setting on or off the Audio Indications in auto mode. I can set the switch, but it is better to do it programmatically.
My first the test here:
Stabilize mode :  https://www.youtube.com/watch?v=meYPmOkk6yM
Auto mode :  https://www.youtube.com/watch?v=UXIEqR_i45k
Paul, don´t know which Multi GNSS you´re using  and how did you mount them. I can´t prove this with CSG M8N and DroTek XL. (both units with 35mm patches) They are not jumping around and are serving constantly low HDOP. So turning off GLONASS might help your setup, and could depend on your location.
I´m flying pretty often @ my shaded backyard as well ,-)
Old MP on laptop shows different meaning of those options. Gnss_mode =1 enforces GPS only. Sbas_mode can be set to 0 - for me it works best this way.
Changing gnss_mode to 2 enforces sbas and i get no sats on eastern usa coast this way.
Wiki has different values listed.
As one fellow reminded me lately, this will do the reset as well:
If I manually go in and change the SYSID_SW_MREV from 120 to 0, push the write params button and then disconnect/reconnect the parameters are restored to their defaults
Saves some time;-)
Hi Guys and Gals,
I regullarly use this little bit of software from Trimble to get a rough GUIDE to what I can expect from my GPS
http://www.trimble.com/support_trl.aspx?Nav=Collection-8425&pt=...
It is a guide but it will help to get a gauge on what DOP values and which sat constellations are in sight ata particular time and place.
Why not just hit the Default button in Mission Planner?  The one on the advanced Param or tree view page.
I thought this also put all values to default.
On point 3. Calibrate Level  I founbd it best to do this once, when I can be sure to make the frame level.  Then NOT to redo the calibration unless thge Pixhawk has moved in relation to the frame.
On another frotn, with the EKF parameters which is the best to adjust the weighting of the GPS to IMU?  I have tried adjusting the Noise BIAS params and this seems to work.  Is this the best place to do this?
I can see that they are already weighted towards the accels so is it better to increace this wieghting or change the GPS glitch params so that the GPS readings have to be tighter?
Overall I have found the latest relaease to be very solid and I am just wanting to fine tune a bit.  Thanks for all of the fantastic work.
The parameter description issue is a problem with MP so I've raised an issue for MichaelO here.
Until that's fixed, the correct GPS_GNSS_MODE parameter descriptions are here.  The @Values show numbers that can be put directly added and put into the parameter.  If you're ok at bit math then the @Bitmask description shows the meaning of each bit in the number.  Eventually MP will be fixed and we can all just use checkboxes again.
So I recommended "3" because this enables the "GPS" satellites (i.e. the US Govt satellites) and "SBAS".  All other systems like the EU Galileo, the Russian GLONASS, etc are disabled.  This is why there are fewer satellites seen but my understanding is that the GPS constellation is the most reliable and sometimes using glonass can actually reduce the accuracy of the solution.
Enabling "SBAS" can also be bad though depending upon where you are in the world.  in the US and Japan it's definitely better to have it, in Australia though it can make it worse.
Hope this helps.
Yes, I agree with Alex and Gervais and created a little wiki page with the three possible methods.
Thanks for consolidating the info so writing the page was easy.
