Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Andy,
The D term filtering is something we have been doing from the very beginning (when we put the D term in) and my reading of their thread suggests they may have used our numbers as a starting point. It was only recently I made it a settable variable to ensure we could get the most out of the faster quads while ensuring the larger quads could be kept low on noise.
The reasoning behind the interrupt based control loops is also something we have been aware of and using for a long time however the process of squeezing the most out of the APM has meant we had to make some compromises there. I have been talking to the other devs about restructuring the way the fastest loops are run to keep them closely synchronized with the reading of the rate gyros and outputting to the esc's. Our setup is a little more complicated because we have multiple sensors running at different rates and therefore we need to be careful how we do it.
There is a lot of great engineering going on in all the flight controllers and it is exciting to see everybody try to get the most out of the technology!!!
Thanks for bringing this up, it is always good to have this stuff highlighted in case there is something we are missing!!!!
Hi!
You can download it from http://www.rappens.se/2015-09-28%2016-53-44.zip , 8 MB so it is to big to attach here.
I analyzed som more and I think it stopped and did some yaw back and forth some more times during the autotune?
Thanks!!
Which is precisely why I think you should be able to disable the internal.. maybe you can now and I missed that? I have often gotten the compass's inconsistent warning. Seems like if I could turn the internal off it would be beneficial. There's no failover for added safety anyway that I'm aware of.
I've had great luck with the mini apms v3.1 on 250's. Just finished building my 4th one and they fly really well all in all. I am thinking though of swapping this one out for a hawk lite before I sell it though just to see how different it flies.
Hi Craig,
I would be very interested to hear how they compare!!!
Please give me feedback on my FPV racer blog page if you don't mind.
Thanks!!!!
+1 - I also would like to have an option to disable the internal compass. I believe it would be beneficial to the system.
it just did it again today, always MAG2 on Y and Z axis only, while MAG never shows any problem...also notice how it fixes itself halfway thru the flight.....is MAG2 the external or the internal compass?
i think there is an option to disable each compass....but which one is MAG2? I find it difficult to tell if thats internal or external
Hi Leonard- Yes I love good news like this :D
I sent you a message here with some added info which will hopefully be of help in advancing the acro capabilities of AC. I would not have bothered to send I did not feel it was significant.
PS it would be great to have an easier method of calibrating ESCs -  components like motors and ESCs tend to get swapped more often on racer / warp quads due to damage and over-use.
I understand that 1 is the ext compass
Is 3.3 out?
Checked in MP for beta FW and I got "APM:Copter V3.3 Quad"?
Or a bug in MP.
I think it´s out since 14 hours.
APM:Copter Release Notes: ------------------------------------------------------------------ Copter 3.3 29-Sep-2015 / 3.3-rc12 22-Sep-2015 Changes from 3.3-rc11 1) EKF recovers from pre-arm "Compass variance" failure if compasses are consistent ------------------------------------------------------------------
