Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Leonard,
sure here are some pics
This pic is from the build off, in the meanwhile i replaced the pixhawk mount with the other type usually offered on the marked which has the flat plates with 4 holes for the rubbers.
This is main view, the copter i perfectly balanced, the weight focus is in the Middle
Hi Pomaroli,
Well, this may be caused by the flexing of the frame but I am coming up empty. The only thing I can suggest trying ti setting Autotune_Aggr to 0.05. However, if you are happy with the tune you have now I would just relax and enjoy flying the copter.
Sorry I can't help more. I will keep an eye out for similar issues with other copters and see if I can work out what is happening.
Thanks for taking the time to give this feedback!!
Hi Trent,
An overheated ESC would definitely fit the bill!!! That would explain why you didn't loose all power. Being your first flight going that long and with extra weight all makes sense.
As you said, that flight doesn't show any signs of the same problem.
Good luck and let us know if you learn more!!
you're welcome leonard and sorry for my poor english sometimes.
Hi Zhang,
I changed EKF_GPS_TYPE to 3, but there was the message “Pre-arm: need 3D Fix” while arming in Loiter mode. Could you attach your param list of craft?
Thanks a lot.
leo
WOW!!!!
Today, a windy day (as usually here) I try Richard recommendation to cover the Pix not to loose altitude, I used a salad bowl and works GREAATTTT!!!!!, It's impressive to watch this copter flying with this wind :O , impressive code too, Many thank's Richard and Dev Team :)  :)  :D
The only thing I don't feel comfortable with this vers is that if I change from stab to Pos hold and throttle isn't in the middle, the copter loose altitude very fast, that didn't occurs for me in older vers; It's only a detail but a newbie perhaps can crash if surprise him/her. But I don't change this vers for nothing older, It's looks much better for my complicated cuad
Richard: You can't find a solution for your Tanaris yet? .
Cala - i had similar happen until I accurately set my throttle midpoint.  looking in my flight data log my hover is at 33% throttle - i changed my mid throttle to reflect that.  now there is only a small difference when switching between poshold / althold and regular flight modes like stab / drift.  Also i changed my althold deadband to 50 from the default 100.
btw I use the rctimer.com plastic dome and flight deck combo to house my pixhawk lite FC- it is not expensive and works great.
I've learned very quickly to get the throttle stick centred before switching to Alt Hold! I think a delay on the switch and a centre stick reminder might be good. Time to tinker with my Taranis! :)
Tested my height following with lidar today. Passing close over my car ( noooooooo ) and even over me and it works beautifully. My only comment is that we need some indication of what is in charge of height,  ( as opposed to altitude ). An indicator on the GCS that the vehicle is height controlled ( sonar/Lidar ) as opposed to altitude ( Baro/GPS )  would be nice. Perhaps even an added channel control to follow sonar/lidar - terrain following?
copter 3.4 anyone?
Thank's Kurt, I'm going to play with dead band perhaps solve, I'm going to re-check the mid throtlle in case too.
This disposable salad bowl is very similar than RcTimer one, fix perfect on my cuad and is very light....now I'm dieting to have more domes ;)......perhaps looks horrible but I'm so happy than I look nice :D
very nice innovative solution. you may want to spray paint the inside of the bowl black, tape off an area inside the bowl first, in front, over the status lights so you leave a clear "window".
hey guys - on the motor test tab in MP, does "A B C D" correspond to "1 2 3 4" as far as motor orientation on the 3DR pixhawk page for X quad layout and pin assignment?  I have no idea why MP is using ABCD instead of 1234.  no one uses that...
