Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I bought the Pixhack for something different. It has internal IMU dampening. Their early versions were not so great, but I have version 2.1 (2.8 is latest). I have no idea how they track the revisions, but there are no versions between 2.1 and 2.8!
Yes, the vibrations are fantastic, so thus far I can say their design appears to work well, but ordered some foam from HK just in case.
I need to know what PID or other parameters to adjust to remove the slight wobble at hover before doing AT. Experience tells me not to do AT unless the copter is stable and good vibration levels. I at least have one part good.
Doesn't look like this vehicle actually flew so I don't think we can trust those Vibe numbers.  Sorry!
I can assure you it did fly. I can also assure you I used the wrong file. What a dope, will try again tomorrow since I cleared out the logs.
Cala,
It's not clear that switching to the internal compass would help and it's likely on some vehicle it would make things worse.  The gyros drift but the drift is quite slow so even without the internal compass, the heading could remain fairly accurate (i.e. within 30 degrees) for a minute or longer.
The logs were still on the pc. I guess with the Lions winning today my exuberance deluded me to think I loaded the correct log. So much for fantasy vibration levels.
l
 thank's for comment, now I know that isn't only my problem, (worse with simple mode) , I'm only flying near me now, to tune, check all things, etc. (...anxious) because I notice that, this week I have to pick up my new gps-ext compass and perhaps it's better to disable the int one.
PD: But I notice too, that this issue is much less with the pix and 3.3 than the 3.21 and APM
DG,
Ok, yes, so about 2x or 3x the levels on my IRIS.  We think things go bad when the vibe levels are over 60m/s/s so it'll probably fly ok.
Now much sense, I'm near that kind of graph, you scared me ;)
Stephan,
Really sorry for the crash.  I'm sad to say this looks like either a bug or missing sanity checks somewhere in the follow-me processing code.  We actually saw this once during beta testing of Copter-3.3 and although we couldn't find the exact cause we did add more checks and it didn't happen again (until now).  I will try and find other ways this could happen and come up with some more checks.
Can you tell me which version of Tower are you using?
EDIT: sorry, I see you've said you're using Tower version 3.2 which is the latest.
Stephan,
If you happen to have a tlog from Tower itself that might also help us track down the cause (although we will look hard in any case).
Randy thanks so much for looking into this.
Yes I am using the latest 3.2 version of Tower.
I was flying many, many times in FollowMe along with 3.2.1 w/o any issues.
I am also using quite often FollowMe with Tower and Solo (FW 1.2) w/o problems.
So this was a quite frightening experience seeing the motors going to stop all of a sudden and the drone crashing just 3 meters away from me.
How can I extract the Tlog from my Android?
Hi I flew yesterday in guided and follow me leash and face me only problem I had it faced the other way
Using 3.3
Stuart
