Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Perhaps it's usefull if you share a photo of your build, It's looks strange that you have so higher values in Roll than Pitch, did you complete well Pitch and yaw autotune?
It's usefull for experts if you share your autotune log too.
@frederico,
    yes, you got lucky there.  That's the exact case where it gets itself into a bad state.
@Hien,
    ok, sorry for the troubles!
To add a bit more detail, internally Copter has an auto-armed flag that should always be true if the vehicle is flying autonomously.  It's primary function is to stop the vehicle from beginning an autonomous mission unless the user has raised the throttle.  In the case of the take-off being initiated from the ground station we were not checking that flag.
Copter-3-3.1-rc1 has appeared in the mission planner so all feedback welcome.
It actually has some additional changes beyond this fix:
  • compiler updated to 4.9.3 (code runs slightly faster than with older 4.7.2 compiler)
  • TradHeli changes ahead of next round of beta testing (should not affect multicopters)
Thanks Randy for the speedy resolution. Yes your video describes exactly what I did before the crash. I will test as soon as I have my quad repaired. :-)
So here is photo of my build.
and log file
hope link will work
http://www.supershare.pl/?d=1440AD4D2
or https://www.dropbox.com/s/gu7qkezv4c1yae6/2015-10-18%2016-29-26.log...
thanks a lot!
Attached are graphs of accels for IMU 1 and 2 and vibration which I believe reflects IMU2 the LMS303D.  This is a 3DR Pixhawk
The accel readings for the Z axis show considerably higher amplitude on IMU2.  It appears the difference is noise / vibration on IMU2. as average amplitudes seem close. But vibration on IMU2 appears factors above IMU1.
The vibration show very low readings on X and Y and higher as expected readings on Z.  On higher motor output / acceleration IMU 2 appears to be clipped whereas I would suspect IMU 1 would be fine.
Looking at the board layout the LMS is out at the corner of the board where I would guess it is seeing some board vibration.
Is this vibration difference  IMU2 being higher a consistent difference typically seen?  Has anyone attempted adding some vibration reduction foam to support the board corner to reduce this?
The copter seems to be handling well even during acceleration but I am concerned around the clipping seen. This was a 15 minute flight and I am not sure if this number of clips is a serious issue.   Obviously 0 is best.  No  issues with Alt Hold very stable on altitude while flying.
I have done a few of revisions on vibration control and reduced the aount of z vibration and clipping events significantly but may have to do more.
Hi folks,
I'm new to this community and I must say great work done my many here, thank you.
Quick question. I just upgraded from 3.2.1 to 3.3. How do I turn off the low voltage audible alarm while my Pixhawk is powered by USB without having to set FS_BAT_VOLTAGE to zero then remembering again before flying. It didn't do it in 3.2.1. Voltage does read correctly on the HUD so I don't need to calibrate the device.
Thanks,
Bob
Very similar than my new build  http://diydrones.com/forum/topics/optimizing-my-first-cuad?id=70584...
I did autotune but without the gimbal in front, then I lower stab pich and roll and rates pitch and roll but pitch stay higher, then I try a second autotune but abort in roll for a lost signal problem and now waiting a calm day to re do for a fine tunning but the copter is flying well, I have to put a cover, look my post. If you want, I can share my actual pids
Randy: It's possible to add to new vers a prearm check against distracted women safe?
If the pilot try to take off in an undesirable mode like Land or autotune for ex. prearm check don't allow you to take off?.
When this can happend? when you have land or autotune in a switch and forgot to unswitch the copter take off completly uncontrolled, autotune goes up and down crazy, fortunetly my copter is designed for that distracted woman and no crash consecuences. :)
What's mean "Err flight mode 15"?
Only a detail, 3.3 is nice. Updating to rc1. Thank's
Never mind. Found a failing USB power supply. Once changed the Pixhawk is now operating as it should, and did,at the correct USB voltage and alarm silent.
Cala,
"Err flight mode 15" would mean that it was unable to enter AutoTune (AutoTune is flight mode #15).  This could happen if the vehicle wasn't in AltHold when you tried to engage AutoTune.
Many thank's Randy, that's explain all; I notice that when the copter can't engage one mode, becomes crazy, I observed in 3-4 oportunities, It's possible to change something in code if copter can't engage a mode stays, for ex in the last mode that was flying well and no become crazy? I observe in the two copters and with APM 3.2.1 and 3.3; only to take in mind, we have to pay more attention what we are doing when we fly too ;) .
Thank you Cala for your answer. I would be grateful if you could share your PIDs. We've got different props but i thing pids could be similar (not equal).
so if i'm flying with gimbal should i adjust pids manualy for only one axis? for example first for pitch and than for roll?
how to start? First from P? or I? or D? or Stab? :) a lot of question for such a "little copter":)
