Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The motor imbalance is quite easy to see from the dataflash logs.  Just take a log from a vehicle doing a regular hover and plot the first 4 channels of RCOU message (assuming it's a quad).  If the distance from the highest to the lowest motor is over 200 or 250 then the motor imbalance could be the cause.  Perhaps one of the motors is tilted.If you post a dataflash log I can peek at it if you like.
hi randy,
that´s sound interesting to check the tilted motors.
can you explain it with a picture. attached is a log of me. it´s 3.2.1. i hope it´s ok in this thread.
thank you very much
Sbus out is not implemented yet. Just make a Y harnes for your sbus. Also, it is much better to use sbus ou pin for RSSI so you have that info on your OSD.
Hello,
I'm unable to use my tarot t2d gimbal with 3.3 on pixhawk. I have been using it connected directly to my rc on channel 6. Today, I setup the camera gimbal on mission planner to RC9 output / rc6 input according to the wiki. The gimbal initializes with the blue led steady ( no signal )  and the cam pointed to the front ( horizon ). When I press the motor switch , the blue light starts blinking and the camera turns downward, but I'm unable to control it with the RC6 switch.
Could someone confirm that it is working with 3.3 version and perhaps point me to a soution?
Many thanks in advance
6 flights today with my rebuilt copter.
Everything is fine.
Good to go!
I think Robert once said that it was working. Maybe is not so difficult to implement. I would also be saffer than using a Y cable
SpeedyHulk,
Here it is for the log, it shows an imbalance of about 100pwm which is fine.  I encourage you to try it yourself though, it's really very easy to produce these types of views.
Leonard/Randy,
  If you get time, would you please look at these Auto Tune results for my latest quadcopter build? It's an H4 Alien 680. The props are APC 13x5.5 MR, smaller than desired, but I could not find the adapters for the 14".  It had one squirrely event during roll while AT, but other than that it went smooth.
Why is the Stab Pitch and Roll so diverged? The COG is darn close, and it seems to fly ok, although only flew it for a few minutes in perfectly still winds :)
Link to flight log
https://www.mediafire.com/?rl6u4rqdx99c52x
An observation.
Yesterday I tried Auto Tune. The copter would not hold altitude while in Alt Hold, which is commonly reported by many. The AT was aborted and I discovered the vibration levels had worsened.
Today after improving the vibration levels by > one order of magnitude, during AT the copter held altitude much better.
Confirmation bias or a connection?
DG,
Great that you got the vibes reduced that much.
Bad vibrations will certainly affect AltHold performance.  It's absolutely critical and we recommend people designing/building copters to check their vibration levels (see First Flight section's Measuring Vibration wiki page) and the live vibration monitor added in Copter-3.3 was added to try and make doing this a little easier.
Copter-3.3.1 is out as the official release now.  Thanks for the confirmation from Miroslav, Yssaril, RandyB, JoeG, Stephan and perhaps a couple of others that -rc1 seemed ok!
Thank's Randy, we don't have to change rc1, it's the same no?
Another thing, when I installed the 3.3 with pix my OSD read all in 0, I have to change sr values before some reading, now I noticed another persons with same problem, perhaps it's usefull to have the correct SR values for OSD as standard params not to have that problem? or if you are not using osd you need different params?
http://diydrones.com/forum/topics/adding-extra-functions-to-minimos...
Thanks for all the Dev's work on the new release.
So I previously was using 3.2.1 and it was working.
I now loaded 3.3.1 on my PixHawk on my desk, only using my USB cable for the power to the PixHawk (as I have often done).
The firmware flash seemed to go ok. I power cycled.
I keep getting errors that I don't remember seeing before:
PreArm: Accelerometers not healthy
So I went to do the Initial setup, and tried the Accelerometer calibration.
Then I get this error:
Place vehicle level and press any key.
Initialising APM...
Initialising APM...
accel[1] not healthy
Calibration FAILED
Ok, what do I do? Why do I get an accel[1] not healthy? I can't remember ever seeing this before.
Or, MUST I test this with a flight battery, and not only powering the PixHawk with my USB cable?
Thanks for any hints!
