Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
No that is not it. I am not talking about selecting RTL manually on Ch5. That is self explanatory, right? :D
I need to know if RTL is invoked automatically by the FC for whatever reason (fence, voltage etc), if RTL is transmitted as the new flight mode in the same manner (same as manually selecting a flight mode is sent over telemetry to Taranis.)
Cala I think you are just having too much fun :D
re- if RTL is transmitted as the new flight mode in the same manner
You mean does ardupilot send the RTL verbal to frysky T1 the same as if you did RTL yourself?
sorry just trying to clarify so somebody else can let you know. Or... I guess you could set a really safe high voltage fail safe and see what it does.
Maiden flight on ac3.3, it was really stable :)
Yesss!, I acumulate and now I have to use all together ;) ....tomorrow rainy forecast :(
When a failsafe is triggered it changes mode just like if you had manually changed it. So, yes, it will show up as RTL in your Taranis.
No that is not it- my info should be clear to one of the devs familiar with AC FrSky output, hopefully one of them is monitoring this thread.  AC does not send verbal commands of any kind over FrSky and I never said anything like that. The verbal part is handled inside the Taranis radio settings.
Francisco, thanks.  So if I set up a Logical switch in Taranis to say, L4 a=x for T1, with a value of 6 (RTL mode), and then set a custom function to call out "RTL Mode" if L4 = 6, it should work right?
The only thing odd I saw in OpenTX is for T1, when setting up a Logical switch it only gives you the choice to set numeric degrees Celsius. So I am assuming that the flight mode values coming from AC are just a numeric Celsius value reported to T1.
Anyway, I'll test it out this next week and report back.
Hi Randy,
Is there a work around for my alexmos simplebgc gimbal? I was able to use it without issues on the previous 3.3 beta build. but now it seems I cannot control the pitch. Previously, i use ch6 on my radio. The gimbal was connected to aux1 like before. MNT_Type was set to servo. but now on the latest build, i cannot use it properly..
My point was is it  reported as RTL when it goes into RTL regardless of what set it to RTL. Yes.. not sure why it wouldn't.. but stranger things have happened.
Hi Randy. I installed 3.3.1 RC1 today to test and issue which I have with no SBUS output on a Pixhawk controller. I´m trying to connect a Storm32 controller. If I make a direct connection between the X8R and the ST32 I get no problem, but I i try to make it through the pixhawk I get no response. I have set BRD_SBUS_OUT to 1
Yeah, I don't see why it wouldn't work.
Yes, T1 is a temperature, but it doesn't matter, just put 6 there and it should work.
