Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm satisfied but just after second autotune The first wasn't good  (autotune>save>autotune>save)
I have large x8  8 kg
Hello,
While following the wiki to configure PX4FLOW and Lidar-Lite v2 on AC3.3.1, I am wondering when does the autopilot actually use the PX4FLOW camera. Would anyone mind to let me know if I am right or wrong in the following.
- Autopilot reads PX4FLOW only in OF_Loiter flight-mode?
- Autopilot reads PX4FLOW in all GPS-assisted flight-mode, but does not read it at all in non-GPS flight-mode?
- Wiki requests EKF_GPS_TYPE = 3 during PX4FLOW test flight. After that I should set it back to EKF_GPS_TYPE = 0 in normal flying?
- Whenever the flight mode requests X/Y position estimation the autopilot reads both GPS and PX4FLOW. EKF then blends them together for autopilot to use?
- OF_Loiter is a flight-mode that needs X/Y position estimation but does not read GPS. It only reads PX4FLOW?
Thanks for clarifying my confusion,
Wilson
I would say I am right there with you, but you have clearly thought this through more deeply than I have. I am getting ready to mount a px4flow but have not entirely wrap my mind around when OF works and if by using it I loose functionality some where else.
I am interested in the answers to your questions also!
Looking forward to an icon in mission planned to enable PX4Flow as a near plug and play option, with a calibration sequence similar to setting the Acc or compass.
All is good time I am sure.
altitude and current draw log. Are the spikes caused by glitch? my esc's are running fine after the flight
 Do the latest firmwares support V and T setup for hexacopters at all?
@Randy, Paul and the dev team.
Your diagnosis was spot on but took me a while to find.  The picture shows #6 position after landing a 15 minute test flight.  I had noticed this after the first episode but assumed it was from the hard landing, broken landing gear after hex rotated into the ground.  This time the aircraft flew amazingly well until the last few minutes and i initiated an RTL witch it performed quite well and landed within inches of take off spot, only to see #6 twisted over 20 degrees.  Faulty pivot mount on the strut.  I'd call 3.3.1 rock solid to have been able to land in this condition at all let alone in RTL.  Great diagnostics and firmware to match.
Thanks to all
No Witches involved, just poor proof reading.
I'm also completely confused on whether I can use optical flow sensor without lidar or not.
Wiki says it does not use sonar readings anymore and I see flat line for EKF5.meaRng.
Lidar is additional $200...
Lidar lite v2 is only 115.00.
http://www.robotshop.com/en/lidar-lite-2-laser-rangefinder-pulsedli...
It would be nice to have the option use the installed sonar or lidar, either way OF is really neat feature.
Duffy,
I'm afraid we only support X and + for the Hexacopters.  It's not super hard to add support, just need to come up with the motor mixing for roll, pitch and yaw.
I live outside their country, and shipment to my place is unusually high.
I agree, having such option would be great.
Tried to calibrate OF, but it seems without lidar flowX/Y and bodyX/Y are poorly correlated, scaling will not make them match (bodyX/Y and GyrX/Y do match).
Wil there be ever oneshot support with pixhawk in the future?
