Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
+1 For that!
It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped.  I know Leonard Hall wants it as well so that increases the chance that it'll happen.
If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
This procedure was recommended a few times. The autotune takes the currrent parameters as the starting point, thus , doing it two times would make the parameters more refined.
If they are OK, with no wobbles, enjoy it!
I have two Pixhawk running arducopter with version 3.3.1 and one with
3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
yes please, oneshot support and blheli 1wire update through copter software
So I can use a pixhawk for 250 racers which needs fast updates to esc and processor of pixhawk is fast enough and software is excellent
RTH functions on a racer with all the close proximity interference of all the electronics ..... :(
Could case a lot of complaints about the excellent software which is designed for stability and not for racers, compass mot V3 for mini racers???
I for see a lot of questions
Hello!
I used version 3.3.1 with coaxial octorotor. I try take off in Stabilize mode. Compass and GPS disable, because next step I want use PX4FLOW. But when I move throttle stick only on one step coaxial octorotor take off very fast and I cann't control it, when I move stick back on one step throttle too small for take off.
When I use 3.3.1 with quadrortor everything all right with take off.
Can somebody analyze my log? I will attach the file coaxial octorotor. thanks!
test flight a while ago, hovered it  3 meters away from me. My quad went to failsafe due to low battery. but instead of landing, it performed RTL instead of LAND. I thought it should choose whether to LAND or RTL based on hardcoded 5m rule? is this normal? Luckily i was able to switch flight modes to cancel RTL else it should have hit the wall.
Hi
I got this result after autotune on a X8, flys OK but values out of range or?
After installing 3.3.1, I noticed a couple of PID values changed: RATE_RLL_IMAX & RATE_PIT_IMAX to 2000 from the earlier 1000 setting.  Did the PID loops change such that what was 1000 on 3.2.1 needs to be 2000 to behave the same on 3.3.1?
I had a hard landing yesterday after trying LAND mode for first time since AC3.3.1 , it went to land but it never slowed down the descent speed before touching down, literally slammed into the ground....I have my land speed set to 45cm/s.....
log attached, anyone that can help out? I have been able to replicate the issue and even sent land speed to 30cm/s and it doesnt seem to make any difference
2 log files attached...i think on the second one i aborted the landing by switching to stab
