Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I live outside their country, and shipment to my place is unusually high.
I agree, having such option would be great.
Tried to calibrate OF, but it seems without lidar flowX/Y and bodyX/Y are poorly correlated, scaling will not make them match (bodyX/Y and GyrX/Y do match).
Wil there be ever oneshot support with pixhawk in the future?
+1 For that!
It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped.  I know Leonard Hall wants it as well so that increases the chance that it'll happen.
If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
This procedure was recommended a few times. The autotune takes the currrent parameters as the starting point, thus , doing it two times would make the parameters more refined.
If they are OK, with no wobbles, enjoy it!
I have two Pixhawk running arducopter with version 3.3.1 and one with
3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
yes please, oneshot support and blheli 1wire update through copter software
So I can use a pixhawk for 250 racers which needs fast updates to esc and processor of pixhawk is fast enough and software is excellent
RTH functions on a racer with all the close proximity interference of all the electronics ..... :(
Could case a lot of complaints about the excellent software which is designed for stability and not for racers, compass mot V3 for mini racers???
I for see a lot of questions
Hello!
I used version 3.3.1 with coaxial octorotor. I try take off in Stabilize mode. Compass and GPS disable, because next step I want use PX4FLOW. But when I move throttle stick only on one step coaxial octorotor take off very fast and I cann't control it, when I move stick back on one step throttle too small for take off.
When I use 3.3.1 with quadrortor everything all right with take off.
Can somebody analyze my log? I will attach the file coaxial octorotor. thanks!
test flight a while ago, hovered it  3 meters away from me. My quad went to failsafe due to low battery. but instead of landing, it performed RTL instead of LAND. I thought it should choose whether to LAND or RTL based on hardcoded 5m rule? is this normal? Luckily i was able to switch flight modes to cancel RTL else it should have hit the wall.
Hi
I got this result after autotune on a X8, flys OK but values out of range or?
