Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
what is going on with 3.3.1 ?
I had for long time 3.1.5 my OEM Pixhawk was flying perfectly
then 2 weeks ago I upgraded to 3.3 . did full wizard from Mission planner. I found out that THROTTLE is not cutting directly to my input but it is delayed and somehow props are still spinning for 1 second when my throttle was down. Then I tried GPS mode and it was not keeping position at all , attitude mode was working ok, and stabilize mode ok.
then yesterday I updated to 3.3.1 and now I got BAD GYRO HEALTH on mission planner but artificial horizon looked ok, I tried the wizard again and it FAILED on accelerometer test . I ignored it then went outside  and right from the start CRASH like gyros would not work at all. so what is going on ? instead working better and more user friendly looks like programmers make our life worse. I think I will go back to 3.1.5 when all was predictable and working fine.
if anyone cares I can add my logs. I mostly fly on stabilize mode and atti.
mu setup : 500mm quadcopter frame , with pixhawk and 3dr power meter and 3dr GPS.
If your accel failed, it's a bad omen for your next flight.  Lets see a log file.  I'm thinking it's going to be the controller, but can't say from just what you've told us.  I've had two Pixhawk's that I returned for this reason.  Though mine were different in the sense the horizon was all over the place.
Very gusty wind here in Detroit.  15-30 mph easy... took off in alt hold. VERY impressed, Pos hold too,,, very impressed. Rock solid it just hangs there like it's on a rail!!!!!!!!!!!!!!
The only thing I notice is my throttle stick seems different. %50 holds fine but it seems different somehow. Was there a default something  with 3.3 and throttle settings??? It's like the dead band got bigger? Is it just me? Is it intentional?   But wow!!! Is the major improvement because of EKF???  I have turned that on and off before.... but this flight characteristics now are way better. Love it... thx devs!!!
Richard,
Txs for the feedback.  Maybe the EKF helped but my guess is much of it is Leonard's work on the attitude controllers and also the improved thrust curve (it was a set of three lines but now it's a smooth curve).
We did resolve a small bug in the throttle input code which we never noticed until more people started flying with sprung throttles (in particular the Solo).  Fixing that did slightly adjust where mid throttle and the deadband are.
3.3 and 3.3.1 have no changes in that area.  This version uses EKF and has checks now to see if the two gyro's are outputting somewhat the same values.  If not then you get the BAD GYRO HEALTH.  Others have reported the accelerometer calibration failing but after repowering and running the setup again it would work.  Flying without calibration is a bad idea.
Hi Randy! I think its a big bug... My Quadcopter does take off in stabilize with ca 45%, and in loiter or alt hold with ca 80%. Why?
@maxgr
ca? What is that?
Nathaniel ~KD2DEY
*with about 45%
Hello! I would like to share with you the altitude controller's amazing performance when powered with XL-EZ4 rangefinder.
It is extraordinary how precisely it can control the altitude, even in extreme low height flight.
Thanks Arducopter team!!!
https://youtu.be/-ZtkwyXZ_cA
Frame: Tarot 680 Pro with 4.4Kg auw weight
nice!
Hi Richard, I live in the thumb. Nice to see a fellow Michigander. Go Lions! Meow!
wow your kidding.. I have a place by lexington. Looking forward to 3.4 and 'boat mode' for some killer lake Huron footage :]
