Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi! I did another test flight with my tbs discovery. I was a bit windy last day. but everything went fine. I raised my quad to 60m without problem, then raised it up to 100-120m and held it there for a few seconds then returned down and landed safely. I reviewed my logs after finding out a very surprising info. My current draw peaked to almost 60A
my setup is this:
sunnysky 900kv 2216
gemfan 1045 carbon nylon mix
DYS 30A V2 esc (blue)
5200mah 10C multistar 4s
normally I see my current draw below 30A. I was bothered after I found out about the current draw. Can somebody analyze my log? I will attach the file. thanks!
I have been playing with the lidar lite and am very impressed with how well it makes my quad hold altitude. It make arducopter still more fun to use!
I am really looking forward to fuller integration of range finders,(during auto missions)and the potential for obsticale avoidance by adding a second forward facing range finder. 3.4 maybe?
Dreaming I know, but 10 years ago who have ever imagined civilians drone in the hands of hobbist running auto missions?
Please Randy, and rest of the development team, tell us how we can help to move development forward!
Thank you again!
May be off topic, but I'd like to stress the issue of compass interference. I just recently re-assembled my new Alien 680 build by swapping out the KDE ESC's that I just could not get to work right with AC. In went the HW Quattro and it has zero issues. Go figure.
So I'm going through the motions and EKF is yelling at me again. Looked at the graphs (love that feature) and there it was; compass into the orange. Drat. The mast is 6"+ from the top of the frame, the main power is underneath. Huh? I demag all steel screws. The rest are non-mag SS.
Then I noticed a live 12v JST connector for the gimbal poking out through a slit on the top frame. Hmm. Tucked it down inside the frame, EKF is happy, I'm happy.  Does that sound logical or just coincidence? Are compasses that sensitive?
by the way, I have performed current calibration prior to this by doing this method:
1.Fully charge your lipo
2. Immediately fly your multi for at least five minutes
3. Land and disconnect the lipo from the multi
4. Immediately, charge your lipo unti full using a smart charger with display (capable of displaying total current used for charging the lipo to full capacity).
5. Connect your FC to mission planner using usb cable and open the Battery monitor sub-tab in Initial Setup>>Optional Hardware tab
6. Look at the Amperes per Volt value
7. Go to Flight Data tab and download data flash logs
8. Review the log file and check the CurrTotal
9. Calibrate the current sensor by adjusting the Amp per volt to actual values. Do the math:
New Amp per Volt = Amp per volt * Total Charge / CurrTotal
10. Type the new Amp per Volt value on the box provided in mission planner for the calibration.
Hi!
I tried to use battery_voltage2 and current2, readings get to Pixhawk but scaled wrong?
I received 15355V, tried to scale it to 15,3V but then I only get 15V. Using a standard power module connected to ADC 3.3V.
Want to use 2 batteries in parallell and monitor each via separate power modules?
Great job with the new version....
//Affe
Affe,
I've never tried to monitor two batteries but it should work if you make most of the BATT2_ parameters the same as the equivalent BATT_ parameters.  We don't us the measurements from the second battery monitor for anything (i.e. battery failsafe) but I think you should be able to see the values in the Mission Planner (or other GCS perhaps) as "battery_voltage2", etc.
Hi Randy,
can you help me analyze my log?
I believe that to be coincidence. Even though it is a "live" wire it is not connected and carries no current so it also creates no magnetic interference.
Randy,
You are right I can see some values in MP but as I wrote I cant scale them correct without loosing the decimals?
My settings for batt2:
BATT2_MONITOR -> 4        (Analog Voltage and Current)
BATT2_VOLT_PIN-> 13       (in MP A12 not sure if this is right since it is numbered 13 in the Picture in wiki)?
BATT2_CURR_PIN-> 14      (in MP A13 not sure if this is right since it is numbered 14 in the picture in wiki)?
And I have only connected pin 3,4 and 6 from Power module, and they are connected to ADC 3.3V on pin 2,4 and 5 and in that order.
pixhawk1
It is a quite Heavy X8 so I was thinking i might go over 60A if I run them via one Power module, and as I was having one spare, so why not try it this way?
I've got a few lidar lite units, but a whole group of new lidar modules coming out.  Check this out http://www.lightware.co.za/shop/en/home/45-sf40c-100-m.html
We really need a way to integrate these sensors into auto missions.  So I'm keeping my fingers crossed lol!
I will try to recreate the compass interference warning. This wire is off the 12v step down regulator, and my understanding is when there is no return path for the current, an exposed wire can emit radiated EMI. No?
It's normal that I start autotune with
ATC_ACCEL_P_MAX,72000
ATC_ACCEL_R_MAX,72000
and after autotune I have
ATC_ACCEL_P_MAX,49814,88
ATC_ACCEL_R_MAX,51907,54
ATC_ACCEL_Y_MAX,12720,53
Tnx
