Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
After installing 3.3.1, I noticed a couple of PID values changed: RATE_RLL_IMAX & RATE_PIT_IMAX to 2000 from the earlier 1000 setting.  Did the PID loops change such that what was 1000 on 3.2.1 needs to be 2000 to behave the same on 3.3.1?
I had a hard landing yesterday after trying LAND mode for first time since AC3.3.1 , it went to land but it never slowed down the descent speed before touching down, literally slammed into the ground....I have my land speed set to 45cm/s.....
log attached, anyone that can help out? I have been able to replicate the issue and even sent land speed to 30cm/s and it doesnt seem to make any difference
2 log files attached...i think on the second one i aborted the landing by switching to stab
I have used standard Octocopter code to fly an H-shaped Octocopter (like your hex shown, but with 8 rotors).  It worked out OK.
I had a quick look.  Has this vehicle flown before?
I don't see anything wrong though I'm not the expert in multirotors.  I see your motor outputs are about 1250uS PWM on the first test.  Then the second test they don't go above 1500, I think it flipped over?
I suspect it might just be that your multirotor is overpowered, or the ESC's aren't calibrated properly?
The copter does not slow to Land Speed until it believes it is 10m above Home Altitude. Your WPNAV_ACCEL_Z is set to 4.5 m/s.  At this speed, it would hit the ground in 2.2 seconds.  Your WPNAV_ACCEL_Z is set to 1.5 m/s/s.  It would take 2.7 seconds to decelerate to 0.45m/s from 4.5 m/s.  The copter did begin to slow and impacted the ground at about 2 m/s.
So it appears everything functioned as it was programmed to.  I think the algorithm could be improved if it looked at the parameters to determine when it should begin to slow down, instead of using a 10m hard-coded setting.
thanks for looking into Rob!!...but it used to work just fine with these same parameters in 3.2.1, I dont recall crash landing like that....i do recall very well what you mention and it slowing down at 10m or so...but not now, at least visually, it doesnt seem to slow down at all...or doesnt try hard enough...
should I decrease the WPNAV parameters both?
well I meant I should increase the accel_z and reduce the accel right?
Ooops, WPNAV_ACCEL_Z is set to 4.5m/s should be WPNAV_SPEED_DN = 4.5m/s
I would decreased the WPNAV_SPEED_DN, and increase the WPNAV_ACCEL_Z.  If you used 250 and 250, you'd have 2.5 m/s and 2.5 m/s/s.  At 2.5 m/s, you have 4 seconds from 10m to impact, but would only take 1 second to decelerate to zero.
You can balance those off however you like.
It is curious, when it passed 10m, it didn't even begin to try decelerating for 500 milliseconds (half a second).  I wonder if that's due to a jerk limiter?  By that point it was already at just 7.5m. So it had just 1.67 seconds to stop.
I think this was just a rationalization of what the value needs to be.  I've been pushing for it to be 4500 for a long time, which is what I typically run.
Another problem is that it appears to have impacted the ground while it thought it was at 2m still.  So obviously there was a height estimation error.
So much has changed since 3.1.5 and I forgot so much since 3.2.1
I'm sure it's been discussed and answered over and over, BUT, if after Auto Tune the copter seems to not hold well in slightly windy conditions, should AUTOTUNE_AGGR be increased or decreased. I did it at .07.
