Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi John,
I would suggest changing
 INS_GYRO_FILTER to 40
and
RATE_ROL_FILT_HZ to 40
RATE_PIT_FILT_HZ to 40
Let us know how you go.
hi please find attached log
many thanks stuart
vibration levels abit high but there was a 23mph gust winds
vibration within normal levels on not so windy days
stu
My setup
17x5.5inch props
390kv motors
30amp Simonk afro esc
10000mah 4s
Pixhawk 2.4.6
Flys for half an hr
ok thanks yea I reduced WPNAV_SPEED_DN to 4.0m/s only and now it seems to be working ok, it slows down nicely at about 10meters and lands softly....thanks Rob
Nice setup but it looks like you push the quad speed envelop to hard. Theoretical max propeller air speed with lowest measured bat voltage approx. 13.6V with 390kV motors and 5.5 inch prop is approx. 12.3m/s. To be able to move air faster increase voltage or change motors and propellers
Hi stubugs,
Sorry, I need a data flash log.
Thanks I thought it might be on limits of the motor and props don't really want to go any more power or I'd loose flight time
Stuart
Thanks for looking into Rob! But when I use prevuious version 3.2 with this coaxial octorotor everything all right (I didn't change battery and didn't calibrate ESC's). I change only version APM. With 3.2 I can control multirotor. With 3.3.1 it flipped over.
I don't see anything in particular wrong.  I'd recommend trying a few things:
  • re-calibrate the ESCs
  • do the motors test to ensure the motor order and direction is correct (check the props too!)
  • if the above doesn't help, try going back to Copter-3.2.1 (it's still available through the MP's previous firmware link) so that we can be sure it's a firmware issue.  If Copter-3.2.1 works but Copter-3.3.1 doesn't then it's likely a firmware issue and we can look into it further.
Erwin,
It depends upon the FS_BATT_ENABLE parameter.  Probably best to peek at what that is set to.
Thank you for your help, I'll try to apply the strategy that you proposed.
Just a quick question. What did you mean by the following?
Check to make sure your copter is stable when quickly rolled and pitched to 45 degrees and the stick is let go. Don't hold the stick to build up speed, this test should be done as quickly as possible.
Should the quad withstand when I do the same but speed it up significantly first?
