Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I have done about a dozen flights now with V3.3 on my littlest Pix, a 320_mm hexacopter.  I had a few issues with the Autotune and PIDs on upgrade, but this thread has helped me sort those out.  Thanks boyz.  I have been pretty satisfied with V3.3
But, today I have landing gear and a bent arm to repair. On my last flight, it inexplicably dropped from the sky.  I have tried to decipher the cause from my logs, but I don't have the experience to determine the issue. It felt like a voltage drop, but the battery had over 11_V remaining and the cells are within .1_V of each other.
Can anybody suggest the culprit? . . .
Hi I have a quad done auto tune flies great with 3.3.1
When in drift mode it can reach 50mph but is OK up to 30/35 mph but above that it starts to dive loosing height tried changing max angle for all flight modes to 30' but still losses hight above 35mph
could this be software or does any one think frame/mechanic have reached its limit on forward speed and power to keep nose up enough to maintain hight
It's not a barometer problem as I cover whole pixhawk in cling film to keep out wind altering pressure on barometer
Stuart
you should NEVER cover the holes on the baro. Use dense foam not cling wrap.
Hi yes there is dense foam over the barometer in the pixhawk case
Stuart
Logs: http://1drv.ms/1MPxlJ5
First file - P value tuning. Second one - more about I value tuning.
Photo: http://1drv.ms/1PuM8I2
The only difference is that GPS is put on stick now (the same location, but on stick).
What Craig is getting at is that you said you cover the whole pixhawk in cling film, which is essentially the same as covering the holes on the barometer rendering it useless.
Oh sorry no I only covered with cling film over the top to stop wind blowing in directly it was no where near air tight or all around
I still got height reading on mission planer
Cheers stuart
sorry missread where you said you covered the entire hawk in cling wrap and not just the baro :(
Hi stubugs,
Can you provide a log please.
Will do but hopefully tomoz as is 11.10at night here lol so if it's not raining I'll try tomorrow cheers stuart
Hi John,
I would suggest changing
 INS_GYRO_FILTER to 40
and
RATE_ROL_FILT_HZ to 40
RATE_PIT_FILT_HZ to 40
Let us know how you go.
hi please find attached log
many thanks stuart
