Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hey Randy,
I've been testing the V2 via PWM connected to the Pixhawk (using master branch). I also see the jump, often to 12.02m. I also see the PX4Flow Sonar jumping to 12.02m.
Did you guys also see the jump via I2C, or only via PWM?
hi please find attached log
many thanks stuart
hi, i have run into this issue that happens sometimes but only seen it in 3.3.x releases, where pix will not enter into a flight mode that requires GPS, but the GPS are ok (i have 2 of them), all I have to do is restart the pix and then it will work fine....log attached of the issue from today....I took off in manual, went to enter loiter or auto, neither would take giving flight mode error....but far as I can see both GPS seem to be working fine....any clues?
A shot in the dark maybe but this kind of unstable behaviour could be due to a too soft anti vibration/ dampening of Pixhawk. How is your Pixhawk held on the frame?
Thanks for looking into Randy! Yes, Copter-3.2.1 works but Copter-3.3.1 doesn't. Attach log for version 3.2.1
The last recommendation I recall was to use one GPS until 3.4 addresses issues related to 2x GPS. Is that not correct?
Yes, as DG says, the recommendation is not to use two GPSs until Copter-3.4 because of the jump if it switches the primary GPS.  Master's has about 1/2 the fix already so hopefully the full solution will be in Copter-3.4.
Hi I used to have two 3dr gps but it kept jumping say a couple of meters so I fitted a m8n which gets between 16 and 18 sats so there is no jump as the 3dr only gets 11 at most but should the m8n fail it hopefully will switch to the 3dr one and at that point I figure a jump would be better than no gps
Stuart
Hi did you manage to look at my log
Stu
On the mount like that:Not sure whether it's too soft. What do you think?
Help!!
I have Compass problems, calibrated OK but high offset on internal Compass. Have I done something wrong during config?
As soon as I yaw I get EKF Compass errors it looks like MagY sometimes follows and sometimes mirrors?
When I fly, land and disarm. and then try to arm and fly again I am not allowed due to EKF Compass errors.
Should I try to disable the internal Compass?
Those dampers look way too close-set to me.  It will cause the controller to wobble and definitely cause problems.
