Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Very gusty wind here in Detroit.  15-30 mph easy... took off in alt hold. VERY impressed, Pos hold too,,, very impressed. Rock solid it just hangs there like it's on a rail!!!!!!!!!!!!!!
The only thing I notice is my throttle stick seems different. %50 holds fine but it seems different somehow. Was there a default something  with 3.3 and throttle settings??? It's like the dead band got bigger? Is it just me? Is it intentional?   But wow!!! Is the major improvement because of EKF???  I have turned that on and off before.... but this flight characteristics now are way better. Love it... thx devs!!!
Richard,
Txs for the feedback.  Maybe the EKF helped but my guess is much of it is Leonard's work on the attitude controllers and also the improved thrust curve (it was a set of three lines but now it's a smooth curve).
We did resolve a small bug in the throttle input code which we never noticed until more people started flying with sprung throttles (in particular the Solo).  Fixing that did slightly adjust where mid throttle and the deadband are.
3.3 and 3.3.1 have no changes in that area.  This version uses EKF and has checks now to see if the two gyro's are outputting somewhat the same values.  If not then you get the BAD GYRO HEALTH.  Others have reported the accelerometer calibration failing but after repowering and running the setup again it would work.  Flying without calibration is a bad idea.
Hi Randy! I think its a big bug... My Quadcopter does take off in stabilize with ca 45%, and in loiter or alt hold with ca 80%. Why?
@maxgr
ca? What is that?
Nathaniel ~KD2DEY
*with about 45%
Hello! I would like to share with you the altitude controller's amazing performance when powered with XL-EZ4 rangefinder.
It is extraordinary how precisely it can control the altitude, even in extreme low height flight.
Thanks Arducopter team!!!
https://youtu.be/-ZtkwyXZ_cA
Frame: Tarot 680 Pro with 4.4Kg auw weight
nice!
Hi Richard, I live in the thumb. Nice to see a fellow Michigander. Go Lions! Meow!
wow your kidding.. I have a place by lexington. Looking forward to 3.4 and 'boat mode' for some killer lake Huron footage :]
Hi! I did another test flight with my tbs discovery. I was a bit windy last day. but everything went fine. I raised my quad to 60m without problem, then raised it up to 100-120m and held it there for a few seconds then returned down and landed safely. I reviewed my logs after finding out a very surprising info. My current draw peaked to almost 60A
my setup is this:
sunnysky 900kv 2216
gemfan 1045 carbon nylon mix
DYS 30A V2 esc (blue)
5200mah 10C multistar 4s
normally I see my current draw below 30A. I was bothered after I found out about the current draw. Can somebody analyze my log? I will attach the file. thanks!
I have been playing with the lidar lite and am very impressed with how well it makes my quad hold altitude. It make arducopter still more fun to use!
I am really looking forward to fuller integration of range finders,(during auto missions)and the potential for obsticale avoidance by adding a second forward facing range finder. 3.4 maybe?
Dreaming I know, but 10 years ago who have ever imagined civilians drone in the hands of hobbist running auto missions?
Please Randy, and rest of the development team, tell us how we can help to move development forward!
Thank you again!
