Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Yes, tried to set the GPS type to NMEA. But this does not help.
what happens if you flash it back to 3.2.1?
When I flash it back to 3.2.1, the GPS works. MP shows "3D Fix" again.
No one an advise ? Or because it´s weekend?
If it's an Alien 680 frame, I have one too and am having problems getting it tuned. From what I've heard many do.  Everything is tight and COG good. AT was done with AGGR at .07.  The copter is not stable after 2 AT's.
My PID's are quite different than yours. I'm starting to think I need to put some good CF props on this bird. With the cheap Gemfan CF VIBE's were lower, but over 500g thrust I don't use them. Currently it has APC MR 13x5.5 and it just doesn't seem to be as responsive plus does wobble.
I've never had a quad with these goofy PID's.
Hulk: Try to repeat pitch autotune or try to reduce it manually, thats in part your wobbles ccd and other problem is that if your camera wobbles probably isn't ccd, it's cmos, are you shure?
Yes, a wonderfull weekend here ;) .....but I'm not have with me my copter :(
The cam is a sony 600tvl.it should be ccd. It's no rolling shutter...more big waves.
I think arducopter has still mega problems with alien type frames. I make a new pitch tune and test or i will reduce p. I don't understand the peaks. Normall it should so clean like yaw.perhaps randy or leonhard thall has an idea. And stab p should be higher.
This is also a Alien 680 tuned at an aggr of .05.  The tune is is rock solid.  This is an X8 though with Sunny Sky 4108s 14 480kv motors and 15" propellers running 10ah4s packs.
was it your 1st autotune try? did you change anything else?
do you have a short log with stabilize and a poshold?
i don´t see my problem optical....only in log and fpv cam
greets
I may be in a wrong thread, but since I am using Pixhawk with 3.3.1 firmware I think my question is relevant.
My setup is shown in attached pic. It is modified Flamewheel clone with RCTimer 2610-920 kv motors, Platinum 30A ESC's. I made it for night flight photos (and possible FPV, so there are 3D field separated camera (Blackbird-1) with 2W 930MHz video transmitter). For regular flight there are two 10W  60 deg. LED and for light effects 100W focused LED on 1 axis gimbal. All peripheral equipment powered from separate battery. Lights controlled via RC ch 9 and 10 through Turnigy solid state relays. The whole thing weight is 2045 g with both batterys, it hover at 45 - 50% throttle.
It flys perfect in Stabilize mode. I tested vibrations, it is below +/- 0.1 g on all axis. When I switch to AltHold mode it almost hold but slowly loosing altitude, it is erratic in Loiter. In log it shows EKF_CHECK-2 error. I read through many discussions on several forums. In most cases it is either vibration or Yaw-error (mine is below 0.2).
I just did complete calibration of both magnetometers with all peripherial ON (errors were balow 0.2) and flew it for 3 min on my backyard - same effect - got EKF error right after switching from Stab to AltHold (did not even use Loiter). Log.bin file from latest flight attached.
Any ideas? I am kindly asking for Randy's comments (it seems that he is the most active in the discussion of this issues in many forums).
Could it be PID tuning, I am still on default values (at first test flight it seems stable enough and pretty responsive, so I decided not to tweak it.) Tuning snapshot below.
It does not seem to paste jpg file in edit mode. will post it in next post.
[URL=http://s1239.photobucket.com/user/86burbguy/media/Mobile%20Uploads/DBBF1154-7A31-42CE-998D-C13C8C6B12DD.png.html][IMG]http://i1239.photobucket.com/albums/ff502/86burbguy/Mobile%20Upload...[/IMG][/URL]
This is on an Alien 680 also. Flys great.
HI. Just next post to add PID tune page
