Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Copter-3.3.2-rc2 is available through the mission planner's beta firmwares link.  Changes are in the release notes but here they are along with a video showing the major reason this version is out.
1) Bug fix for desired climb rate initialisation that could lead to drop when entering AltHold, Loiter, PosHold
2) Fix to hard landings when WPNAV_SPEED_DN set high in RTL, Auto (resolved by using non-feedforward alt hold)
3) Reduce Bad AHRS by filtering innovations
4) Allow arming without GPS if using Optical Flow
5) Smoother throttle output in Guided mode's velocity control (z-axis now 400hz)
Any testing that people here could do before we push it out as the official release would be greatly appreciated!
I've drastically improved roll responsiveness by upping ATC_ACCEL_R_MAX. Autotune had set this to a very low value (53000), I increased it to 180000 and now the copter feels much, much more responsive.
So the $1m question is if I now try autotune on this - which actually feels pretty good - will it make it better or worse?
Too much wind at the moment to try it out!
Many thank's Randy, load and try to test this weekend
I loaded up 3.3.2-rc2 on my QAV250 and flew a little in stab, poshold and althold in pretty windy conditions. All seemed well. Switching from stab to poshold and back again at hover throttle didn't result in any noticeable drop - seemed to work just fine. Wind holding was ok, somehwat limited by the accuraccy of my GPS. So thumbs-up from me.
I make a little test because of high wind today.
To reproduce the issue on my copter I take off in stab, , switch to pos hold, land, switch to stab, take off again in stab, try to hover in stab, switch to pos hold (there I loose altitude after update) and now works well, if the copter was climbing in stab and switch to pos hold, after update, there, he didn't do the issue. Thank's Randy to solve, tomorrow  better forecast I try again larger time.
Today tested AC3.3.2-rc2 on my quad-copter. It has a Lidar-v2 and px4flow.
In AC3.3.1, I was unable to arm in AltHold when FLOW_ENABLE = 1. It happened the GPS reception is also bad (so bad it couldn't pass the 3D-fix pre-arm check if I armed it in PosHold mode). Now with AC3.3.2-rc2 I can arm in the same situation.
However I crash the Tower-v3.2.0! Whenever I attempt to change the EKF_GPS_TYPE from 0 to 3, the Tower-v3.2.0 crashes. So I haven't test optical-flow-loiter in this flight.
I use Mission planner (1.3.32.12 build 1.1.5803.19723) to review the dataflash log. I see several funny error codes:
Err: 195-203
Err: 193-0
Err: 255-11
What are they?
I fly AC3.3.2-rc2 in stabilize, altHold with Lidar-v2, and posHold. Overall very happy with it. The altHold now is very *solid* when I land it. No jumpy altitude anymore when my copter is very close to ground (less than 1 meter). Thanks to the range-finder feature!
an unrelated question. I bought a USB-fpv-video-receiver from CUAV. It can receive video signal on 5.8GHz and stream video to smartphone/PC via USB. Can Tower display the video coming from USB?
Thank you very much for the great work!!
^^^ nice to see this one, i had a few hard landings myself because of it, and broken gear legs...will try first thing tomorrow!
Hi randy! I got a big problem :-( with 3.3.1 and 3.3.2 rc2 the copter takes off in loiter/althold with about 80% of throttle given by me. In stabilize it takes off with about 45% of throttle. What can that cause and how can i fit it? In the logs i saw that the thrOut is much lower than the thrIn when trying to fly in loiter/althold...
Loaded up 3.3.2.1 on two of my birds and put them through every possible combination of maneuvers switching between modes at random, I became confused but the aircraft handled everything in stride, even with fairly heavy winds. Landing modes spot on, Nav control looks great.
Thanks for the hard work,
RB
When upgrading from 3.3.1 to 3.3.2, is it necessary to recalibrate the accelerometers and compass or are the previous calibrations maintained?
Thank you
Michael
I didn't do it.
Is there no THR_MAX parameter in 3.3.x? I have gone through the wizard for a Hexacopter in X, but my parameters do not include a THR_MAX and my copter will not take off (motors spin and almost take off, but do not).
Attached pic showing no THR_MAX after using the wizard for Hexacopter in X.
