Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm the same way I can't STAND the idea of taking off in any other mode except stab. Then I get it to where I want it. Then switch to alt-hold, or loiter, or auto etc. Took me FOREVER to allow it to auto land land and I STILL rarely do so unless I init RTL or end a mission.
if you engage RTL in the end then it is absolutely required to change routine and engage GeoFence so firmware will not let you to start and fly until system acquires acceptable GPS lock and gets your initial position correctly, otherwise your start with GPS coordinates from who knows where may result in RTL into who knows where.
GeoFence is annoying as it takes forever for it to finally acquire that '3d Lock', whatever it is, as it may sit 5 min or so having 13-14 sats in 3D mode before it finally satisfies, but afterward it is flying OK.
Also, after my fights with drone doing toilet bowl and other GPS glitches - an only solution is to buy a separate BEC with a _very_ good LC filter and power your GPS units from that separate BEC, not from your flight controller COM ports. Difference is quite dramatic, in both speed to acquire locks and with in-flight stability.
After all that done I am now always start in position hold and vehicle does not dart sideways anymore, does not try to fly away anymore either. Only other thing - on dual GPS vehicles you still need to change the option to disable automatic GPS receiver swap function until Randy and Co will change logic not to use actual physical coordinates from GPS units but an average delta between positions GPS units return, as different GPS units never return same actual number for coordinates no matter what you do.
Code really needs  to be adjusted to take care of that - to trace actual movement delta from both units and not actual coordinates value as latter results in the drone darting from one stable position to an another.
Hi
I us a Ublox NEO-M8N as my main gps which gets 15 sats in my living room and a second 3dr gps which is still thinking about getting a lock in the house with gps auto switch on it never actually switches gps but 3dr one is there should the m8one gps one fail as I go a couple of miles out best be safe than no backup
Stuart
I'm having lots of problems with mavlink telemetry both through bluetooth and minim OSD. minim OSD now almost never works. Resetting the board doesn't help. Repowering very ocasionally works. I think its more likely that these devices simply aren't receiving mav data. Is there anyway to make this more reliable? I'm also going to try going back a couple of revs because it wasn't this bad before. Could still be my hardware, but just seems odd.
Anyone else any thoughts? I have done tons of searching, but no luck getting any closer to finding this setting.
Still unable to find the THR_MAX setting in 3.3.1 with Hexacopter in X. Does anyone else see it? Is it a missing setting in this version? My copter won't take off.
Its as simple as setting correct SR settings for the correct SR port# and choosing the correct serial port. P.s. also, if you are using a **hawk its a god idea to reflash bootloader.
p.p.s. Do not forget to disable flow control for the minimosd serial port.
Yeah, I've done all that and its been working fine until the last couple of days
Just an update. Seeing lots of "accelerometers not healthy" errors. Used to get these occasionally now all the time. If I set INS_USE1=0 does that stop the pre-arm checks on the 2nd IMU?
Also what's going on here? Logs attached. clip0/clip1 have step changes. What would explain this? Are these values cumulative now?
I have a mini apm 250quad v3.2.1 throttle max is there but on my pixhawk v3.3.2 no throttle max on my quad or hex but both fly fine have you calibrated your escs just a thought
Stuart
Finally completed an autotune on roll. It resulted in very low Roll_P (0.04) and Roll_I (0.04) - very different to my manual tune above which has Roll_P (0.16) and Roll_I (0.03). Difficult to say which feels better as they both fly quite well. The autotune version seems softer. Be interested in opinions on which is better and pros/cons of both.
Autotune log
