Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thank yo for your reply Cala
It will be nice once the Wiki catches up on all these changes. Just a shot in the dark here but what is your MOT_THST_MAX set at? Mine is 0.95.
Same, 0.95.
Anyone run autotune with parachutes on board and armed?  Just going to autotune a new rig that happens to have dual Skycat's on board and wondered if it would be a good idea to take them off.  Wouldn't be all that great if they fired lol!  The chutes are designed to save the payload...  But not the multi rotor so much at about 17'/sec.
today more flights, more test switching to stab and pos hold and works well
If you are in loiter/althold then the copter will attempt to hold altitude so you will need more throttle input to overcome the FCs attempt to hold altitude, this is how its supposed to work so nothing to fix. Out of curiosity why are you taking off in loiter or althold?
Loaded 3.3.2 rc2 on my 450 and 550 quads. Autotuned both and flew a bit this afternoon.  All went well.  Only thing I saw was the 550 tended to have a minor  "quiver" side to side.  Probably a slight vibration problem.  Was testing new props.  Will fine tune and recheck but believe that it is my problem not 3.3.2 rc2.
Thanks Randy & team for your excellent work and fast turn-around.
Michael
Yup, I agree wit Nathaniel.  Just one thing.. taking off and landing in AltHold, Loiter or PosHold should work a-ok.  I take-off and land in these modes all the time.  If it doesn't work, I'm happy to have a peek at a dataflash log file.
@Nathaniel Tyson Taking off in GPS modes or Alt Hold has been SOP for quite some time with other flight controllers. It doesn't strike me as the best of ideas but nonetheless for many people it's totally normal and if you have a good GPS signal there's really no reason not to.
Oh I see, Seams like an odd thing to do to me, lose sensitivity at a critical phase of flight. But to each there own. Thanks for the response.
You don't actually loose responsiveness, it's just a different approach or style to lift off. You raise the throttle up to around 50% and the flight controller ramps up the speed as required to get it to hover height. I think it came from the evil world of DJI.
As I'm a control freak :-) I always takeoff/land in stabilize.
But as I am mostly flying in highlands, before flying missions, as a SOP I always arm and takeoff in one of the GPS modes first, to make sure I have a good GPS lock
