Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi
I us a Ublox NEO-M8N as my main gps which gets 15 sats in my living room and a second 3dr gps which is still thinking about getting a lock in the house with gps auto switch on it never actually switches gps but 3dr one is there should the m8one gps one fail as I go a couple of miles out best be safe than no backup
Stuart
I'm having lots of problems with mavlink telemetry both through bluetooth and minim OSD. minim OSD now almost never works. Resetting the board doesn't help. Repowering very ocasionally works. I think its more likely that these devices simply aren't receiving mav data. Is there anyway to make this more reliable? I'm also going to try going back a couple of revs because it wasn't this bad before. Could still be my hardware, but just seems odd.
Anyone else any thoughts? I have done tons of searching, but no luck getting any closer to finding this setting.
Still unable to find the THR_MAX setting in 3.3.1 with Hexacopter in X. Does anyone else see it? Is it a missing setting in this version? My copter won't take off.
Its as simple as setting correct SR settings for the correct SR port# and choosing the correct serial port. P.s. also, if you are using a **hawk its a god idea to reflash bootloader.
p.p.s. Do not forget to disable flow control for the minimosd serial port.
Yeah, I've done all that and its been working fine until the last couple of days
Just an update. Seeing lots of "accelerometers not healthy" errors. Used to get these occasionally now all the time. If I set INS_USE1=0 does that stop the pre-arm checks on the 2nd IMU?
Also what's going on here? Logs attached. clip0/clip1 have step changes. What would explain this? Are these values cumulative now?
I have a mini apm 250quad v3.2.1 throttle max is there but on my pixhawk v3.3.2 no throttle max on my quad or hex but both fly fine have you calibrated your escs just a thought
Stuart
Finally completed an autotune on roll. It resulted in very low Roll_P (0.04) and Roll_I (0.04) - very different to my manual tune above which has Roll_P (0.16) and Roll_I (0.03). Difficult to say which feels better as they both fly quite well. The autotune version seems softer. Be interested in opinions on which is better and pros/cons of both.
Autotune log
You actually might be right - a bunch of these settings appear to have been changed. I didn't do it so I guess it happened when the firmware got updated. Grrr.
Yes, I run autotune with parachutes on board and armed, no problem
