Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Yesterday, my copter failed during a full throttle raise.
I don't know yet why it came down, but I was in stabilize mode and it started failing during that mode, so GPS and MAG can't be the cause.
I tried to hold it by switching to loiter, but it didn't change anything.
Because of the rotation and the autopilot logging all the time, I thought it must be motor or esc failure. But the motors and escs are working fine even after the almost 60 meters falldown.
It fell into the field and one motor holder broke.
Here is a video, a picture (after the crash and with the fixed motor mounting) and the logs. I hope you can help me find the cause.
https://youtu.be/fbg2rrQhQwU
Here are the specs:
Quadrocopter 580mm
RCTimer 5010 530kv
Afro OPTO 30A ESCs
6s 5Ah 30C battery
Pixhawk flight controller (AUAV-X2)
Arducopter 3.3.1
if you are getting a lot of clipping then your vibs are too high and a lot of people are reporting it is because the bells on their motors have too much slop and removing the slop has worked wonders for them. I had the same issue on a hex with brand new motors. I've since sold off that hex and built a T960 and it no longer has the issue with the same flight controller :) Seems extreme lol but I was going to sell it anyway. The new frame and AVmount producrs nearly 0 vibs and 0 clipping.
pretty sure he said he is running DJI opto and DJI motors which means he can't run the endpoint calibrations as the DJI stock firmware doesn't support it.
No its not that. Here is a log from earlier, same copter, earlier FW. Vibes are about the same, but zero clip.
And clip doesn't go up and stay there - look at the graph you will see what I mean. Something strange going on.
Hello Dave, Have you checked your motors
Hello Dave,
I thought it could be a motor sync issue, but after taking a look at your logfile it seems that they are fine.
There is something going on with ekf. Don't know what is it. Someone more experienced with ekf would probably figure it out. I see that the ekf mag innovations are high and your vibe(x,y,z ) are very high despite the IMU vibration levels are fine.
The jello in the video confirms that is is pretty much either a vib issue or a desync issue or possibly both. Normally a spin like that means one or more of the motors went wonky. This could be an intermittent ESC issue, cold solder issue, a wiring issue, or a motor issue.
In a desync / esc issue shouldn't the rcout channels log the failure by its attempt to raise the throttle in order to try to maintain the attitude?
I do agree so much.
I do want to make tests inside my office, and I need to override checks. I believe  that ARMING_CHECK = 0 would bypass all checks. However I could arm 3.3.1 when disabling GeoFence mode, which is a bit weird since I still have PosHod mode in flight modes...
Thanks for your answers.
I checked the motors and ESCs and they were still working fine. But I will do high load tests again today.
The copter flew perfect before the crash at this day and the day before, so I don't think sync issues could be the cause.
I am an experienced solderer and I made sure the solder joints were all perfect!
See this is the thing about "faults" is the never really go "hey, I'm about to break" Just because they worked "yesterday" doesn't mean they will work today :( And the thing about these darn desync issues is that they don't always pop up and rarely when you expect them. Intermittent problems are the hardest to diagnose. The logs "should" give you an idea where to look but I am so out of touch with all the new logging info that I would not have the 1st clue where to look. You might not even have the needed logging enabled. There are quite a few videos on desync issues and how to reproduce them so you might want to take a search on youtube.
Are you sure all of your props were tight? The only time I have seen that kind of spin on one of my hexes was when it spun a prop lose and down it came spinning like a top. The only time I have had a desync issue was on my 250 quads and they tend to just flip and crash.
But I would definitely look at your vib levels even so as they are not good and are bound to cause you issues in the future. The video showed some pretty heavy oscillations [vibes] and whilst I do not think they are what brought down your bird "this time" I would fix them before flying again.
Would it be possible to post a log with the copoter flying OK? I´m very confused about the log you posted because I can´t find the spinning in the mag or imu readings. In the log it looks like a controlled descent.
There is definitely something wrong with the sensors - in the map logging there i a sudden jump in position along with an EKF error.
