Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Tags:
You actually might be right - a bunch of these settings appear to have been changed. I didn't do it so I guess it happened when the firmware got updated. Grrr.
Yes, I run autotune with parachutes on board and armed, no problem
Yesterday, my copter failed during a full throttle raise.
I don't know yet why it came down, but I was in stabilize mode and it started failing during that mode, so GPS and MAG can't be the cause.
I tried to hold it by switching to loiter, but it didn't change anything.
Because of the rotation and the autopilot logging all the time, I thought it must be motor or esc failure. But the motors and escs are working fine even after the almost 60 meters falldown.
It fell into the field and one motor holder broke.
Here is a video, a picture (after the crash and with the fixed motor mounting) and the logs. I hope you can help me find the cause.
Here are the specs:
Quadrocopter 580mm
RCTimer 5010 530kv
Afro OPTO 30A ESCs
6s 5Ah 30C battery
Pixhawk flight controller (AUAV-X2)
Arducopter 3.3.1
if you are getting a lot of clipping then your vibs are too high and a lot of people are reporting it is because the bells on their motors have too much slop and removing the slop has worked wonders for them. I had the same issue on a hex with brand new motors. I've since sold off that hex and built a T960 and it no longer has the issue with the same flight controller :) Seems extreme lol but I was going to sell it anyway. The new frame and AVmount producrs nearly 0 vibs and 0 clipping.
pretty sure he said he is running DJI opto and DJI motors which means he can't run the endpoint calibrations as the DJI stock firmware doesn't support it.
No its not that. Here is a log from earlier, same copter, earlier FW. Vibes are about the same, but zero clip.
And clip doesn't go up and stay there - look at the graph you will see what I mean. Something strange going on.
Hello Dave, Have you checked your motors
Hello Dave,
I thought it could be a motor sync issue, but after taking a look at your logfile it seems that they are fine.
There is something going on with ekf. Don't know what is it. Someone more experienced with ekf would probably figure it out. I see that the ekf mag innovations are high and your vibe(x,y,z ) are very high despite the IMU vibration levels are fine.
The jello in the video confirms that is is pretty much either a vib issue or a desync issue or possibly both. Normally a spin like that means one or more of the motors went wonky. This could be an intermittent ESC issue, cold solder issue, a wiring issue, or a motor issue.
In a desync / esc issue shouldn't the rcout channels log the failure by its attempt to raise the throttle in order to try to maintain the attitude?
I do agree so much.
I do want to make tests inside my office, and I need to override checks. I believe that ARMING_CHECK = 0 would bypass all checks. However I could arm 3.3.1 when disabling GeoFence mode, which is a bit weird since I still have PosHod mode in flight modes...
Thanks for your answers.
I checked the motors and ESCs and they were still working fine. But I will do high load tests again today.
The copter flew perfect before the crash at this day and the day before, so I don't think sync issues could be the cause.
I am an experienced solderer and I made sure the solder joints were all perfect!
45 members
1472 members
282 members
470 members
57 members
Powered by
