Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
See this is the thing about "faults" is the never really go "hey, I'm about to break" Just because they worked "yesterday" doesn't mean they will work today :( And the thing about these darn desync issues is that they don't always pop up and rarely when you expect them. Intermittent problems are the hardest to diagnose. The logs "should" give you an idea where to look but I am so out of touch with all the new logging info that I would not have the 1st clue where to look. You might not even have the needed logging enabled. There are quite a few videos on desync issues and how to reproduce them so you might want to take a search on youtube.
Are you sure all of your props were tight? The only time I have seen that kind of spin on one of my hexes was when it spun a prop lose and down it came spinning like a top. The only time I have had a desync issue was on my 250 quads and they tend to just flip and crash.
But I would definitely look at your vib levels even so as they are not good and are bound to cause you issues in the future. The video showed some pretty heavy oscillations [vibes] and whilst I do not think they are what brought down your bird "this time" I would fix them before flying again.
Would it be possible to post a log with the copoter flying OK? I´m very confused about the log you posted because I can´t find the spinning in the mag or imu readings. In the log it looks like a controlled descent.
There is definitely something wrong with the sensors - in the map logging there i a sudden jump in position along with an EKF error.
since your running 530kv motors with simonk firmware esc the sync issue is very possible. That spin was like I have never seen before. I would highly doubt that any SW issues such as EKF would cause that type of spin. Highly doubt it.  If it was a flyaway maybe even a high pitch or roll uncontrolled but that spin no way.
Randy
Is this the file I need to direct APM P2 to install in my quad frame / pixhawk to test boat mode? ArduCopter-v2-2.px4
Here is a log of the Copter flying perfectly fine!
Had to rar it because otherwise it would be over 7mb.
didn't have a smaller log with active GPS.
Thanks for your efforts!
how can I reproduce this type of error?
would you recommend BLHeli then?
I first want to find out the issue of the crash before changing anything.
First I highly,highly recommend BLHeli for those motors. Second yes you can recreate it if its an issue but not sure how since I have never had that problem and have always been using BLHeli  Never had to search it but I have heard that you can recreate it. You can also improve it by lowering the PWM frequency I believe with RC_SPEED parameter or something similar. If I were you I would flash BLHeli and that way you have nothing to lose really. And do more tests with props upside down.
If it is a sync issue I am not sure how you can actually find that out from logs. Since its from ESC onward and pixhawk does not have visibility there as far as I am concerned.
hey, you are of course right but it's really strange, that it flys fine and from one second to the other it just fails.
I am also very new to the logging thing and just did basic checks before. Therefore I also don't know what to look for.
The props were all tight!
What vibe levels are ok? Do you mean the VibeX, VibeY, VibeZ parameters?
The high z vibes are from the landing, I guess.
ok, thank you very much for the information.
I will now first try to recreate the issue by full throttle individual motor tests, let's see how that ends..
you can try giving your ESC+motor extreme change of throttle input. if there is out-of-sync issue waiting to happen, these test should kick them right out!
make sure you use your fight controller hardware to drive your ESC/motor speed. for making sure the signals in your test-bench is exactly the signals during actual flying.
I had a crash with my big copter also due to out-of-sync!! the ESC was DYS simonK 30A! since then I bench-test ESC for checking any out-of-sync hazard.
you may check out my video on out-of-sync test: https://youtu.be/NfBgwYjyU1k. hobbywing Pentium pro 30A is also unhappy with my copter! while hobbywing x-rotor 40A works perfectly and it is "certified" to be in mid-air with me ;)
Saw this over at RCG
http://www.rcgroups.com/forums/showpost.php?p=33278428&postcoun...
If you're running BLHeli and 14.2 then you need to upgrade to 14.3
"I've just read that 14.3 is out due to 14.2 having motor glitch issues near high throttle. Check it out."
I´m quite sure there is no problem with your esc. While the coopter descends all RCOUT channels are close to each other
and the copter doesn´t flip. It follows the desired attitude quite well:
I think there is something wrong with the IMU of your AUAV. In the ATT readings there is no sign of the spinning we can see in the video. Looks like the FC tried to compensate a wrong detected spin from the IMU:
