Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The log where the pictures are from is from your first post. Perhaps you can post the crash log again? I can´t download the log from the second post.
Hi Dave,
I am looking at the correct log but it doesn't show any yaw spinning. I am pretty sure you have uploaded the wrong log.
The log from the first post (http://diydrones.com/xn/detail/705844:Comment:2137266) is definitely the crash log, as you can also see at the errors, it even detected the crash in the end!
You are right, the download of the OK-file doesn't work. Will upload that again when I come home.
Not being able to see the spinning in the att.yaw log data also confuses me hard.
Has to be an error in that sensor then doesn't it?
Also what do the big jumps in that data mean? The heading can't jump that fast?
Hi Dave,
Those errors don't mean this is your crash log. I am 99.9% sure (I am never 100% sure) you have the wrong log. Nothing matches your video.
I agree with you but regarding the first part of your answer, I thought the following:
If there were sync issues, you can't see them in the log data. The ESC just fails and the motor stops, or am I wrong?
Will check the IMU when I come home. Thanks!
will double check, when I come home, thanks.
Hi Dave,
sync issues will be clearly seen in your RCOUT log if you had the correct log. You will see one of your outputs pegged to maximum while the others struggle to keep control. You will also see the yaw log go nuts as it spins.
Usually with one motor out of sync the copter will drop on that side and the FC will try to correct attitude by increasing RC_Out of that motor. There is nothing like that in your log.
thanks guys.
yeah, you can just see the spinning when you click "Show Map":
I had two crashes when a prop tip broke off it looked sort of like that. That was the last time I used cheap props.
Hello Richard,
all my props are fine (just one slight cut-in at one prop which definitely came from the crash) even after the 60m drop. I was really lucky.
I use Aeronaut CamCarbon light 13x6 props.
Here is a pic I made after the crash.
Yea I’d say your quad looks damn good for a 60M crash! This is probably unrelated but one thing I had happen once was somehow two of my arms got twisted and as luck had it it was two opposing arms hence the motors spin the same direction. What happened then was it could not compensate for the yaw effect that caused so even with full right yaw stick it continued to yaw left. However it didn’t cause a crash and of course it was evident the moment I took off. In my case the aluminum arms get bent slightly in travel. I was amazed at how little it took to create that much of an issue. Just looking at yours I wonder if two of the motor mounts twisted on those round arms? But of course the log would show it trying to compensate with full yaw opposite it's actual yawing.
