Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Then obviously not all ESCs do this then. The other ESCs I use don't do this on my 800 hex, min quads etc, and the ones I now have are the first time I have used them. Anyway thanks for you input, its now crystal clear.
Hello Dw: the best vers is beta 3.3.2 rc1, read Randy red notes upside, there is explained, stable has an unconfortable bug,
Copter-3.3.2-rc2 is available through the mission planner's beta firmwares link. Changes are in the release notes
(https://github.com/diydrones/ardupilot/blob/master/ArduCopter/Relea...) but here they are along with a video
showing the major reason this version is out.
1) Bug fix for desired climb rate initialisation that could lead to drop when entering AltHold, Loiter, PosHold
2) Fix to hard landings when WPNAV_SPEED_DN set high in RTL, Auto (resolved by using non-feedforward alt hold)
3) Reduce Bad AHRS by filtering innovations
4) Allow arming without GPS if using Optical Flow
5) Smoother throttle output in Guided mode's velocity control (z-axis now 400hz)
Hi Leonard,
http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId...
Is the latest successful tune. This was in pretty quiet conditions.
My other posts:
http://diydrones.com/xn/detail/705844:Comment:2134664
http://diydrones.com/xn/detail/705844:Comment:2134141
http://diydrones.com/xn/detail/705844:Comment:2131508
http://diydrones.com/xn/detail/705844:Comment:2113903
I think my original issues were because one ESC was badly calibrated. Once I fixed that things worked better modulo the low P values.
Hi Cala and Goran
Thanks for that. So is rc2 considered safe and stable to use? Is there an expected release date?
Hi Leonard,
So the 0.004 value was set by autotune both in roll and pitch. If I do a manual tune on roll then a value of 0.003 seems pretty stable, 0.004 is borderline. So I'm interested in the 0.001 value - that seems way below any setting that would lead to fast oscillations. Is it worth me trying this? Like I said n my previous post the main issue seems to be not having a high I value - that leads to a lot of problems. Also what determines a good stab roll value? In the Dave C method he recommends a value of about 3. Autotune selected 9 in my case - what does this affect and how can I tune it? There doesn't seem to be any way to map it to channel 6.
I attached a log with me manually tuning Roll P from the autotuned values.
Hi Andy,
The low D term is so Autotune can tune it properly. It would be great if you could give it a go. Autotune needs to be able to go lower than the optimal value to find it that is why it needs to be so low.
Based on your issue we are reducing it by default.
If you could take the time to do Autotune in some good conditions I would appreciate it!!
Thanks!!
Hi Leonard,
No problem - gale force here, so won't be today!
So just so I get this right - reduce D and leave everything else the same and then run autotune?
Just roll, or roll and pitch? If roll and pitch do I need to reduce D in both before running autotune?
I've just bought some 2200mAh batteries so am hoping I have enough power now to get good tunes everytime.
Thanks!
You are an experienced pilot, nothing is safe and stable guarantee with this toys ;) It's as your oun risck, but if you use the stab release, be carefull to switch from stab to loiter, pos hold, etc., I try many times with beta and the issue go away, but I'm only an user, Randy go to send to stable when he consider safe but really I like this last vers, great dev work. What vers is your last one?
Hi Andy,
Just to be clear. Don't change your tuning parameters of Rate_P_D or any others. What you have done is fine.
I want you to reduce AUTOTUNE_MIN_D to 0.001. This parameter is the minimum D that Autotune can use.
Does that make sense?
Thanks!!
I was planning in pushing AC-3.3.2 as the default over the weekend but got caught up with the xracer so I'm just reviewing the support forum and this thread to ensure -rc2 hasn't caused anyone troubles.
It's not too different from AC3.2.1 so I think it's generally safe to fly.
Thanks Leonard, got it. I'm glad I asked!
