Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Richard,
Boat mode isn't included in Copter-3.3.2.  If you're feeling brave you can load up "master" though you can go to MP's  Install Firmware page and press "Ctrl-Q" to get V3.4-dev.  Many of the devs fly master but please remember it is broken from time to time.
anyone have this??? http://www.hobbyking.com/hobbyking/store/__81874__PixFalcon_Micro_P...
thoughts... settings etc etc.. mods youve done...??
i have one flies pretty good.. getting alot of errors though mainly variances on the compass.. but ive removed the checking feature on that .. if i turn the copter by hand left and right it goes to a green light.. kinda weird... but thats indoors.. im going to try 3.3.2 rc 2 outside tomorrow.. i re set everything from compass rc transmitter even esc calibration.. to make sure im good..
just wondering if anyone has it what you think etc..
Brad,
Sorry for the slow response.  I may have answered your question on the APM:Forum but in case that wasn't you, you can use MOT_THST_MAX to reduce the maximum possible output to the motors.
Wilson,
Thanks for testing and sorry for the slow reply.
I have no idea what those error messages that you've seen are.  Our highest error message is 20 so I'm unsure where 195 has come from although my guess is it's caused by some corruption in the log or a display issue in the MP.  If you have the log still I can take a peek.
We've got a new discussion re optical flow which you've probably already found but here it is in any case.
Feel free to report that Tower issue here.  Maybe it's crashing if it gets a message it doesn't understand although really it should have protection against that kind of problem.
If the video from the USB-fpv system is H264 then it should be possible to get it displaying in Tower but maybe pinging the Tower guys through their community page is the way to try and get that working.  I googled for the USB fpv system from CUAV but couldn't immediately find it.  If you have a link I'm a bit interested in checking it out.
I've got one but I've only put it through some bench tests, I've never actually flown it.  It seemed ok to me except it doesn't allow easy connection of the ground wire to the ESCs.  We recommend connecting the signal and ground wires for all ESC to the Pixhawk because without it the ESCs can be confused about the voltage coming across the signal wire which can lead to ESC reliability problems.
So people seem happy with Copter-3.3.2-rc2?  I haven't seen any unexplained problems that I think could be caused by the new release so I'm tempted to push it out as the default tomorrow... I guess I'd just like to hear from people here who have tested it that it seems ok to them as far as they can tell or "no don't release!" if you've seen problems.
By the way, I think there will be a copter-3.3.3-rc1 within another week or so with a couple of very minor changes.
+1 from me - I have done many flights on my QAV250 with rc2 good success. My only snafu was my serial settings getting borked, but I suspect that's a MP issue.
BTW did you see my question about "Accelerometers not healthy"? I was flying one day with rc2 when it was much colder (0C rather than 15C) and I was getting these all the time. Does switching off IMU2 disable it for pre-arm checks also?
Altimeter, geo-reference, laser range-finder
When a laser range-finder is used is it possible to use this altitude as the default for the geo-reference process.
As I understand, currently laser-altimeter is not used for auto missions, and probably either barometric or GPS is used for geo-referencing.
Hi! I have two problems since rc2, i think :-(
1) when i raise the trottle stick, nothing happen till 90%. In the logs there is 90% thrIn and about 45% thrOut. Same with pitch and roll for example, the copter starts to do the action when the stick is shortly before its limits.
2) since rc2, mission planner / tower says "check throttle threshold" and it is not possible to arm until i uncheck the receiver failsafe. It worked till rc1/rc2 I think
Nothing changed in config, did the normal wizard to configure all.
Would be very nice if you can help, randy! ;-)
Hi
Plugged mine in in the house about 20 deg went outside armed and flew then after a few mins would not hold position as it was 0degs
started to slop off so I think gyros or accelerometers didn't like temp change
Reconnected power outside and flew fine once it calibrated it's self at colder temp
Stuart
you should ALWAYS ALWAYS ALWAYS let it acclimate before taking off. You are begging for disaster otherwise. The sensors NEED to acclimate. If it is warm inside and cold outside I always let it sit unplugged for a good 20 minutes before even thinking about plugging in the battery. These MEMS units are super sensitive and heat/cold can affect them in all kinds of scary ways.
Re-calibrate your ESCS and make sure your throttle hover is set back to 50% until you get it worked out.
