Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
you should ALWAYS ALWAYS ALWAYS let it acclimate before taking off. You are begging for disaster otherwise. The sensors NEED to acclimate. If it is warm inside and cold outside I always let it sit unplugged for a good 20 minutes before even thinking about plugging in the battery. These MEMS units are super sensitive and heat/cold can affect them in all kinds of scary ways.
Re-calibrate your ESCS and make sure your throttle hover is set back to 50% until you get it worked out.
O, ok, thank you Randy for responce. So if compass movement doesn't agree with lets say acc data this message will be triggered as well, correct?
No problems here.   Stabilize, alt hold, pos hold, auto mission, land all worked fine no issues.
+1, No more change mode issue
Randy,
have you made any tests so far regarding the ICM-20608/MPU9250 and 4kHz sampling to eliminate the need for vibration isolation? ;-)
Looking forward to AC 3.4 (3.5)!
Are you referring to Linux rt AP like a Pi2 Navio+?  This would be nice to see.  Just got one : )
Hi Cala
Yes, I fly OK but I loaded ver3.2.1 after some repairs a few weeks ago and then put it away to work on a project then came back to this and just wanted to catch up.
The snow will stop me flying until the weekend so I can wait until 3.3.2 becomes the default, Thanks Randy , great work.  your ongoing development is superb.
The purpose of the simulator was to identify ESC sync issues. They are caused by fast variations of throttle input. With the simulator, I can put out much faster variations of throttle, but it still didn't fail.
Hello George, sorry for the late answer but I was busy working on the copter :D
I also hear that sound and am wondering what it came from.
I agree, that it sounds like something is breaking.
The issue is: I am so sure that the mount didn't break in the air because of the following reasons:
After the crash, the broken off motor mount was exactly where the copter was, so it couldn't have fallen off during flight.
If it would have been broken off during flight (not fallen off fully), the still spinning prop (the Pixhawk was still telling the ESC to turn the motor) would have at least scratched an arm or something but it hasn't.
As you can see, It's just unreal and I can't believe it.
Speaking about the video you posted:
I agree that this is the weakest point of the motor mount (they are out of plastic) and if it breaks, it breaks at that point, but i don't think it can break because of the thrust (also tried it at my bench)
Shaun,
I was referring to Randy's comment about the XRacer. It is the first autopilot of the new FMUv4 Pixhawk generation (see: https://pixhawk.org/modules/pixracer and http://www.auav.co/product-p/xr-v1.htm) and it is already (partly?) supported in the master branch. So it will be interesting interesting to follow the development.
And since the Navio+ also has an 9250 on board...
Hey leonard, sorry for the late answer.
please also read the post I made above (here: http://diydrones.com/xn/detail/705844:Comment:2141745)
the arm that broke is arm 2 (rear left).
To your thoughts at 1:
sync issues were tested at my bench and I didn't find anything unusual :/
Ice could have been at the props but if so, it couldn't have been much, as I didn't fly high before the throttle burst.
Also I put circuit board paint at my ESCs to protect them from any water.
interference on the signal line could have been there, but I don't think, that could be the cause for that sudden failure.
See the above post for information regarding your second point.
One arm was slightly rotated after the crash (maybe 3-5°) but as I said, I couldn't move it afterwards. It must have been from the hard crash.
I have no idea what caused the vibrations :( maybe I just have to live with this not understandable crash of course mostly because the copter was too far away to see the decent good enough to see any breaks :/
