Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Randy,
Probably busy after holidays and upcoming release.
Can you please take a look at my issue.
Thanks..
Copter-3.3.2 has just been released as the official version.  It's exactly the same (except the name) as Copter-3.3.2-rc2.  Changes from 3.3.1:
1) Bug fix for desired climb rate initialisation that could lead to drop when entering AltHold, Loiter, PosHold
2) Fix to hard landings when WPNAV_SPEED_DN set high in RTL, Auto (resolved by using non-feedforward alt hold)
3) Reduce Bad AHRS by filtering innovations
4) Allow arming without GPS if using Optical Flow
5) Smoother throttle output in Guided mode's velocity control (z-axis now 400hz)
Thanks again to the beta testers on this thread for helping run it’s through its paces over the past few weeks!
Hi Dave,
It looks like copass 1 was cutting out but I will have to let Randy an Paul handle this one as this isn't my strong suit.
Sorry I can't help more!!
Hi Leonard,
thanks anyway for having a look.
I think this is a good example for maybe detecting a failure in ArduCopter (if there is one), because there were almost no control inputs and all of a sudden the aircraft flies away while not responding to control (this is probably because of the failsafe?).
So I am now hoping that anyone else can help me find the cause of the flyaway/crash.
Thanks in advance :)
I've had a look and as Leonard says, the compass failures during this flight at total of 7 times with the first failures appearing 3 minutes before the final crash (the vehicle is disarmed/armed twice during this last 3 minutes).
The compass failure leads to an EKF failsafe which triggers a LAND.  This should be a pilot controlled land meaning the pilot should have had control of the roll and pitch (much like AltHold).
Things go horribly wrong soon after it switches to Land.  I think the Pilot was requesting full Pitch back (see diagram below) but as you've noticed the actual pitch and roll separate from the desired (see 2nd pic below).
This suggests a mechanical failure.  The pilot/controllers are asking the vehicle to pitch back but instead it pitches forward.  During this time the front two motors (#1 and #3) go high as does the back left (#2) while the back right (#4) goes low but still this doesn't correct the attitude error.
Another suspicious thing is the battery voltage.  If the battery monitor is functioning correctly the battery voltage drops an incredible 8V when the motors go to full.  This happens during the crash but also much earlier in the logs as well (at 6min30sec).  This suggests the battery's C rating is far less than is required by the motors.
Dave,
My reply above is really all about the last few moments during Land mode.  Leonard and I have had a look and before this it looks like the EKF's yaw has jumped suddenly.  This is a job for Paul to look at so we will ask him to look tomorrow.
sorry for the troubles!
Hello Randy,
thank you very much for having a look at this.
In the moment you investigated in your post above, the aircraft already tried to fly through the wall, crushing the props.
Unfortunately it didn't quite make it (maybe because of the battery C rating :D).
(the aircraft flew at the wall and didn't stop the motors until 2 seconds passed. The sound of this moment was fearing! As you can see in the logs, motors didn't stop although the throttle was put to minimum there was absolutely no reaction to the RC commands given!)
Thank you for the identification of the problem and also thanks for telling Paul.
thanks for your answer, Richard.
I didn't do motor/compass yet, but as you can see, I was just hovering in this test and there was almost no power drawn by the motors.
No pre flight checks were turned off.
I don't know what my offsets were anymore, sorry.
Thanks, will do this kind of calibration, if it is built up again.
@Randy
Great job. installed today, just waiting for the weather to clear. Thank you for your efforts to make this system great,
Hi Leonard,
So did autotune on Roll with AUTOTUNE_MIN_D set to 0.001. It wasn't that calm, but it's winter here I'm afraid.
The tune completed and gave me PID values of 0.0466/0.0466/0.0016
The copter flew pretty well. I then landed and set Roll_P on channel 6 and tuned this up in flight. I was able to get to about 0.15 before I noticed some small vibration in the wind. So again a 300% increase on what autotune had given me. The copter then felt much more responsive.
Both logs attached.
Had a strange GPS experience with 3.3.2-rc2.
Basically you can see that late into the flight the num sats drops to 0 and the HDOP goes to 99 and the copter hits RTL. However, nothing else is awry - including in the UBX messages. The GPS appears healthy and the signal quality appears healthy. Is this just a glitch or is something else going on here? The thing that is puzzling is that in the GPS glitch in the first part of the flight all of these things move in tandem, but for the second its only HDOP and numsats.
Thank you very much for looking into this.
I have a few further questions:
Did both compasses fail? I have an additional external compass.
What caused the fail? I want to avoid it for the future. Was it a wrong calibration?
Why does the aircraft fly away? The GPS reception was perfect and as I was in Loiter, the position should be held.
I thought the compass is just used for the heading.
