Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Dave,
So Copter-3.3 only ever uses one compass and it won't fall back to the internal one if the main one fails (this may change in Copter-3.4 if the EKF can determine that the internal compass is ok).
In this case, the EKF's heading estimate became off by 90 degrees because it "reset" the heading when the compass recovered.  It sounds like Paul will add some extra protection before it does the reset.
Because the EKF's heading was off, the vehicle flew off in the wrong direction.  So for example, if the GPS says it's too far east then the vehicle tries to fly west.  But with a bad heading it might fly south.  After a few seconds it figures out that it's flying in the wrong direction but it can fly rather far and fast in that time.
I'd just like to clarify that you only have 1 external GPS attached right?  Trying to attach two external GPSs won't work and could explain the compass health failures (and possibly the bad data).
Randy, could you please clarify if this flight would have been recoverable under normal control if the mode was switched back to stabilise?
Okay. I think of a simple check whether the deviation of the orientation compared to the last value is too big. If it is too big, it could be compared to the deviation of the other compass. If that one is fine, it should switch to that one and if that's also not plausible (the aircraft can't turn by 90° in 0.1s from one loop to the other (glitch)). A glitch should be recognized and the aircraft should switch to stabilize or land mode.
I also thought, the detection of flying in the wrong direction would be faster. Copter should immediately detect, that it is flying further away from the desired position (GPS) and there should be a failsafe triggered.
But maybe just everything happened too fast..
Yes, I have only 1 external GPS with integrated compass attached (Drotek M8N XL).
Hi Randy,
Can you please look at my log, and posted compass issue reported few days ago?
Link to the post
Thanks...
I made larger flights with new release with FPV and notice that some times, when I was in pos hold and pitch to start the fpv fligth, pitch react more violent than usual but them the fligth was normal, I remove the gimbal and the issue stays there but not always, that's the strange, I download the log and notice that pitch didn't track desired one
Any idea what happens?
I only notice the fpv camera loose, It's possible the cause?
FnoopDogg, yes, switching back to AltHold or Stabilize would have allowed the pilot to recover.
Any suggestions on improving noisy IPD EKF values? It appears that it is mostly related to a Noisy Barometer. I've got vibrations well below acceptable levels.
The Pixhawk is housed in an rctimer dome.
I loose about 5-10 feet of altitude transitioning from hover to directional flight. I've increased EKF ALT Noise to 3.7 and its subdued the rather aggressive drop to a sustained slow drop over about 10 seconds vs 1-2 seconds.
Still would like to improve on this.
did you foam the baro? Yes even with it in a case and yes even with the RCTimer AVDome. I had similar issues with one of my hawks and it too was in an AVDome and some dense foam and a recalibration did wonders.
Also did you make sure to adjust Hover_Throttle to match exactly what your STAB hover is in mission planner?
BTW Tlogs are pretty worthless. You need to attach an actual .LOG/.Bin that you download from your Hawk.
It is a 3DR manufactured Pixhawk. Opening it up and adding additional foam was my next idea. It remains in the 3DR case under the dome.
How do you recalibrate the barometer?
I meant ACC and MAG as I don't know of any way to calibrate the baro.
I think it does that itself at every reboot.
