Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Kenneth: I had the same issue with vibs under acceptable levels during long time but vibes were my problem at the end, be shure that isn't the problem.
Sloppy motor bells can also cause some of these issues.
I'll relook at vibrations. I've been using the Copter 3.3 Vibration tool in mission planner. I'd assume that motor bell slop would show up as vibration.
Kenneth,
Looks like a tlog, if you've got a dataflash log I'll take a peek at it.  If it really is baro noise, then it's a known issue on the to-do list here but there's no guarantee we can do anything about it in software actually.  The best solution is a physical change to the frame.  Here's the diydrones discussion on this topic.
Hi Randy,
I'd greatly appreciate it. What I notice is a very noisy IPD which looks to be caused by a very noisy baro. At least in comparison to the wiki.
Using the 3.3 vibration tool it looks like my vibrations are acceptable.
Here's the .log:
https://www.dropbox.com/s/xk2klyey5tjc54m/2015-12-02%2016-28-17.log...
It would and mostly the Z axis
I think the issue you linked to is a "Climb" issue and his is a "drop" issue. I've always had a climb issue since back in the old APM days and not just APM but even my old MultiWii boards. And to be honest. I have always kind of liked it :)
yes, your vibs looks good, It's look different than my vibes problem
Hey guys, I have a Y6 running 3.3.2 and today I decided to test its max carrying capacity, by adding about 3kg payload bringing total weight to about 8kg, it was flying fine with 6-7kg I designed it to carry, however at 8kg It constantly wanted to rotate CCW. I've checked RCOut logs and it looks like motors 2,4,6 were at 1700, while motors 1,3,5 were at 1400. Does it suggest that I should be runni g bigger props at motors 2,4,6?
Hi Artem,
This is actually a really interesting question. You need to increase the drag for a given RPM. Increasing the diameter of 2, 4, and 6 may do this. But with the interaction of the upper and lower props it is very hard to say.
So a long story short, I don't know but I am really interested to hear what happens when you try different things. You can increase the pitch on the lower props, you can try increased diameter on upper or lower props, or you can increase the CV on the lower motors.
Let us know how you go!!!
Thanks leonardt, I've ordered a few 1655 cf props from china, will test with both - upper and lower. Btw, did you mean KV (CV)?
The scarse info on coax setups I was able to find suggests that lower props should have larger diameter. Inceasing the pitch is usually not enough.
Hi Artem,
I use 13x5 upper and 14x7 lower. Rcout is almost equal for upper and lower motors.
