Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Look at the compass?_dev_id. My pixhawk have the internal ID = 131594. My external ID = 73225 , it is a genuine 3dr ublox gps. In my conf , the compass_dev_id is the external  and compass 2 is the internal. You shoud set the compass_primary to wherever your external compass is at. Try that and see if helps.
I have never used compass_learn...
Thanks for the advice, I do have the external as primary. I ended up moving the pixhawk and the zubax another 10mm off the deck and it seems to have helped a bit. I did four consecutive calibrations and they were not too far off from each other and passed pre arm checks each time.
Cheers, RB
I attempted to upload 3.3.2 coming from 3.3.1 and the upload completes fine.
But when the "please wait for musical tones to finish before clicking ok" pops up I do not get any musical tones even after several minutes.
The hawk board won't connect to mission planner or do a start up cycle when the battery is connected. The small lights flash, but the large led stays dark.
I have tried using different USB cables and tried loading ardu plane also. Each time the up load completes but no musical tones.
Using the latest MP 1.3.32.13.
So how do fix this?
Try first holding the safety switch down and powering up the hawk. If this fails backup your SDCard and format it Fat32 and then see if it doesn't completely the boot cycle. Try flashing back to 3.1.5 and connecting via console and do an setup/erase and setup/rest
Any updates on boat mode?
Winter is coming... so boat mode is not in high demand, but I'm still curious.
I only notice that your current had fairly periodic spikes to 0. Seems like periodic ESC glitch. Check your CURR pllot.
Have no idea for the reason.
Thanks for taking a look at the log! It does seem there is a power issue. I have a dual battery setup and I'm now wondering if one battery is loosing connection? They have separate power leads to the distro board and I only have one battery being monitored by diy power module. I have seen the compass variance error happen randomly with it just sitting on the ground not armed but I guess this could still be the issue. Guess that is where I will start looking.
Thanks again. Open to any other recommendations.
When you say "on the ground" is this on concrete? I've seen rebar play havoc with the compass' and it goes away when I move it over to the grass..
Nope, on grass. Just weird because I've never had an issue like this before.
I would suggest disabling the internal compass as it doesn't use it anyway even if the external fails. FYI it may or may not have anything to do with 3.3. I have had to do the compass calibration and then the compass mot a couple times before I stopped getting that error even with 3.2. Did you re-do the compass calibration when you went to 3.3? It might juts be finicky like mine [ and many of them ] and unrelated to 3.3. But if your certain the external is fine might want to just disable the internal and issue solved.
+1
I will give this a try but the current drops are still bothering me. What is strange is that the voltage doesn't really change, only the current dips. Also, compass 1 mag X and Y clearly show a deviation coincident with a current drop but compass 2 (pixhawk internal correct?) shows no deviation.
I have redone compass calibration and compass mot with no difference on both external compasses.
I've attached a screenshot that clearly shows the above and I have attached another log showing a longer flight with greater issues. This log is from the csgshop M8N XL, so this behavior is present with two different external compasses.
