Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I take it 3.4 is only something for the brave to try at this point? While I do have a test quad for experimenting, a death wish for Dixie Cup is not desirable :)
Yea probably not the smartest thing I've done flying pre- beta.. But  I've been very keen on boat mode and it seems they have that worked out.
[MAV 001:1] APM:Copter V3.4-dev (f60f0e80)
[MAV 001:1] PX4: 546f2064 NuttX: d48fa307
[MAV 001:1] Frame: QUAD
[MAV 001:1] PX4v2 0036002D 30345101 37383933
I went through 4-5 batteries with no issues in many modes.
The only thing I notice is it takes longer to arm. A couple times I got some weird stuff.... 'new home location'....Sounded off on Tower even though I had 18 sats at the time. One time I did RTL and it went 1000 feet from where it should have. cmmmmmm who knows... but never any stabilize issues.
Did you calibrated your ESC's after adding a new one?
It could be that the new ESC is out of sync with the others.
That would be the first thing I would do after changing one of the ESC's.
thanx Igor .. yes  i did calibrate the ESCs..
I have bin looking around here on the forum now for any thing simulare.. starting to belive its the cold wether.
but i dont know sins i have not hade it up flying good before the cold wether started here,
maybe some one could confirm  that if i disable the 2 IMU it would  be better ? no when this cold wheter fenomen for pixhawn happens dose the craft become unstabile?
Good Morning (=
I have done some testing with AC 3.3.2.
Maybe I found some bug. Maybe.
1)I attacched 3 compass 1 internal to the PixHawk and 2 to the I2C.
I can start the compass calibration, but it read only 2 compasses.
The strange thing is that it seems that the data by external compass 1 and external compass 2 in a certain way interferes with each other.
If I disconnect one of the I2C connection all work right, and I have no problem with compass calibration.
2)Landing Gear Function with AC3.3.2.
If I attach and configure the Landing Gear it happens that at the boot of Pixhawk the Landing gear goeas up.
After the boot is finished, the Landing Gear goes down.
But why at the boot the Landing Gear goeas up?
Maye the PixHawk emit HIGH PWM signal at the boot?
It happens with Radio ON also with radio OFF.
So it does not depend by the radio or the switch position.
I had tryed in so many ways but always the same result: gear up at PixHawk boot.
You can not use 3 compasses. The 2 external compasses have the same i2c address [this can not be changed until the makers of the units pull their heads out and allow us to set the i2c address ourselves] and since they both have the same i2c address the flight controller can't control them. Where did you see that it was a good idea to try to use 3 compasses?
I WISH I could get my gear to go up or down using the hawk. I have to attach mine to my RX directly and just use a switch on my Taranis. Works fine but still annoying.
I do not see that is a good idea using 3 compasses XD I simply would like to test. I like to test new things. So after the test I reported it.
About the landing gear. Any solutions?
Hi I us the gimble channel and rc 7 to make my landing gear go up and down
Stuart
My Bluetooth connection also doesn't work any more after updating Mission Planner 1.3.32 to 1.3.33.
Worked again after downgrade to Mission Planner 1.3.32.
I'm using F2M03GXA bluetooth module.
I somebody could confirm I would open a ticket in Guthub.
I did some debugging on 1.3.33 code.
Seems that when mission planner try to open serial port, it runs some fix port routine and also tries to write data to the socket. I assume that it does make sense for some scenarios but for bluetooth it just kill the po port. Commenting this lines do open the Bluetooth with no issues.
What happens if you apply 5V from a BEC to your landing gear while the signal wire is disconnected ?
It depends on your landing gear controller, but hopefully nothing happens.
