Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Supposing that you know what you do when desactivating checks: you need to disactivate GeoFence to get rid of the GPS checks.
All pre arm check boxes are unticked in the mission planner screen planned for configuring the arming checks. Still no joy. Could it be a mission planner issue?
OK, after reading the same discussion on Google discuss, it seems illogical to not show then the geofence check box with the arming checks check boxes; and then when the user se!ects disable pre arm checks, it should uncheck also the geofence check and show it visually.
The current way it is managed in 3.3.2 is an undocumented behaviour change versus previous 3.2.x and causes confusion. My proposal is above: be transparent and inform the user with explicit messages in mission planner.
Such demands for highly functional firmware that you paid nothing for. My proposal is this; show the developers a little more respect. All of the developers are open to suggestions but the hair goes up when demands are made by novice users. Be kind and enjoy the platform we have been given.
Bravo !
!? Where do you read disrespect toward developers? Read twice and have some respect yourself for non native English speakers who might not be able to express themselves with your demanding stylistic language nuances. Can you do the same in french ? Go ahead.
Keep calm... and please excuse my english too :)
Of course if we post here and use 3dr platform it is because we enjoy it and try to make it even better. I pulled an issue on github for this exact same change, which is not a problem for novice user. Maybe Hugues is in the same situation: flying big and expensive copter for professionnal use. When 3.3 was released, the question: should we use it now or not? I gave it a try only with 3.3.2 and after some tests I am now flying it.
My point is that developpers do a great job, but some of the first 3.3.1 bugs (baro modes...) and changed behaviour on arming check parameters made me not confident for days to weeks. (No disrespect for anyone).
And dont get me wrong, I compile my modified versions for more than 2 years now. Please just keep documentation up do date when deep modification on the code logic is done, "prearm checks" on the wiki for instance.
Please accept my sincere apology. Your English is good enough that I did not recognize or think that you are not a native speaker. One of the things I have enjoyed the most on this forum is the friendly and helpful people from all around the world. I will try to follow my own words and be kind and more understanding before I post.
Cheers,
Randy Bachtell
Thx happy now :)
This is well said. And I respect totally, I should say even admire the dev of this community.
+1 devs and Hugues too, he's a professional but helps lot of people here for free :D ; I'm a disaster english speakers club too ;)
@Cala, Manu B, and Hugues,
It's not about how we converse in another language but how we take the time to understand other cultures and perspectives. Something I did not do and something I am not proud of. I am not a young man, old age is near but wisdom somehow stays far away. I have received much help from this community and contributed very little, as I learn more perhaps I can also contribute.
Thanks to all
