Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Don't worry Randy, we are all young people here trying to learn new things, doesn't matter the cronologic age ;)
Ok it is not my bluetooth driver's fault, it is indeed a Mission Planner problem of version 1.3.33.
1.3.32 works perfectly.
confirmed. First thought is was my bluetooth driver, but as you are saying, version 1.3.32 works!
Hello, I almost crashed today as my copter went crazy in stabilize mode while trying to position to land. It began to drift hard and I had to steer fully against the drift to catch it again. After estimated 2 seconds, it was stable again and I was able to land luckily. There was almost no wind!
I only see ERR EKF_CHECK in the log. Maybe you can help me find the cause.
I really thought this is almost impossible when flying in stabilize.
Here is the log, please have a look towards the end:
https://www.dropbox.com/s/m7uyhq0grc9telx/2015-12-21%2017-06-54.bin...
With the next battery, this issue also happened somewhere during the flight in greater altitude. After I noticed it, I switched to loiter, which caused the copter to go completely retard, giving full throttle while flying towards a certain direction. I catched it switching back to stabilize and landed.
Here is the second log containing this:
https://www.dropbox.com/s/2261m91jzg3rejf/2015-12-21%2017-25-45.bin...
I had great luck not to crash today.
I really want to know what is wrong with the Pix these days.
I am flying a Hexa with AUAV-X2 board running Copter 3.3.2 stable.
Sunnysky 980kv motors with 10x5 props, 30A escs, Drotek M8N XL GPS on 4s.
Any help is appreciated.
Hi Dave
You're probably better off asking here:
http://ardupilot.com/forum/viewforum.php?f=111
or here:
http://ardupilot.com/forum/viewforum.php?f=80
This thread was for beta testing of the 3.3 code which is long over, even though in the last week or two it even seems to have expanded to general 3.2 and 3.4 questions..
Yes for servo deploy. That means that landing gear is open in start before flight.
Look this page: http://copter.ardupilot.com/wiki/landing-gear/.
Then look the values in this channel(from mission planner radio controller) that use for landing gear and change properly . For fail safe decrease this values .(ex. from 1750 to 1700) .
I solved my problem about the Landing Gear (=
First at all: thank you very much to everyone!
The problem was the following:
Landing gear that opens on copter start up.
Every time I plug the battery the landing gear open itself.
The solution was the following:
Use the Safety Switch.
I had disabled the safety switch.
With enabling it every problem was solved!
You have bad vibrations. Pretty sure that's the cause. Look at clip0/clip1 - it's clipping all the time and your vibe values are very high. Everything in the EKF is struggling - even earlier on in the flight, its only at the end that things get bad enough to cause an issue.
The thing I don't understand is the GyrX offset decreases rapidly at the end. Not sure if this is vibration related or not.
I wouldn't fly in anything other than stabilize with things the way they are - loiter is really chancing it!
somehow, I don't receive the activation mail :(
I also found that out now. But only in Z axis, am I right?
My FC sits in a case and this is mounted on Hobbyking FC mounting foam pads. What can I do to reduce the vibrations further?
I am wondering, why the copter almost crashed although I was flying in stabilize?
Here are two screenshots from the flight where the loiter flyaway occured:
I read in the Wiki, that if the EKF4.SV and SV value is above 1, the EKF stops using the GPS for calculating the position and the velocity.
Now why did it do that? As you can see, I have perfect GPS reception (hdop ~0.7, sats 13+).
Also the Mag failed for some unknown reason:
Shouldn't be caused by vibrations, I think.
Same behavior with the stabilize flight:
I don't understand why the copter behaved unstable despite flying in stabilize mode which has nothing to do with GPS?!
Thanks for your help.
I've always used a pixhawk on the two plate with rubber-thingees mount which has always worked great.  I then tried the hobbyking orange foam that the wiki suggests and it was a complete disaster for me - I got all sorts of barely recoverable control issues even in stabilise mode, so I went back to the two plate mount and worked perfectly again.  If you're getting high vibes it will certainly affect stabilise mode and it's a complicated subject with no single answer, so if you're having problems then try a different solution until you find one that works.  If you're getting clipping and high vibes then fix this first as it will always make your flights unstable, gps is largely irrelevent at this stage.
