Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
if you are using Tarot medium and large landing gear you can very well fry your landing gear controller, lookup on rcg I've posted couple of pics where power protection circuit is untouched, while the microcontroller chip is fried.
That's good to know. The only thing holding me back has been the extra weight, but hear many stories of the LG failing.
Hi all
and thank you for great job in 3.3.2
I connected the signal wire to Aux1 (pixhwak) from tarot retract and the ground and 5v to voltage regulator. the result is in the follow video
https://www.youtube.com/watch?v=gZSSq6pkSos
Artem,
  I started a discussion on RCG about coaxial efficiency per eCalc authors. I tried various prop combinations and found the most stable to date was using Xoar 15x5 top and Xoar 14x7 bottom, tried different timings as well which did make a difference.
As you can see, I had the same problem as you:
Below is with Xoar 15x5 top and Xoar 14x7 bottom. I bought some 14x8 but broke one of the blades and never reordered. I now have genuine T-Motor 15x5.5 top/bottom and it is not as stable; haven't flown it for quite some time but want to put the Xoar 14x7/14x8 on the bottom. One thing I'll say is the cheap props flex way too much and cause oscillations.
I also believe the axial distance between the props changes things as well, and with much confidence conclude no two Y6's are the same (had three of them), nor does one size fit all. I'd like to try BLHeli firmware on the HW Xrotor ESC's on this copter.
Xoar 15x5 top Xoar 14x7 bottom. Very stable and reduced VRS substantially.
Link to RCG discussion:
http://www.rcgroups.com/forums/showthread.php?t=2365475
Link to eCalc essay:
http://ecalc.ch/calcinclude/help/xcoptercalchelp.htm#hints
Hi Leonard,
Does this give you what you need?
andy
Hello!
I had 2 smooth fligths with 3.3.2 in Stab/altHold/PosHold, all ekf in green. It was testing flight for our last quadcopter, and we reach our new flight time record: 45min without payload. Behaviour was good even with throttle for hovering as low as 33%, and full throttle in Stab mode was scary, 2.5kg racer is not usual :)
Next big test is tuning same large quad with regenerative breaking activated on 6S, I guess I will have to lower PIDs...
Nothing happens.
That's right. In my case nothing happens.
I'm using X-Cam X6 original landing Gear. By KongKopter.
I can not obtain the same result.
Of course if I switch the CH7 I can open and close the landing gear at command.
This is not a problem.
The real problem is that when I switch on the PixHawk, PixHawk command the Landing Gear to Open.
So PixHawk have an High PWM signal at the startup.
Is this possibile?
Issue : disabling arming checks parameter does not function.
Just installed 3.3.2 on a quadcopter, pixhawk.
The arming_check parameter is without effect, whichever value is set.
I can't produce a log since I can't even arm...
Anyoone seen this too ?
I'm using 3.2.1 on APM2.6 and having an annoying alt-hold problem. It's a medium quad and hovers at 50% but even though I have throttle mid in the parameters set to 500 it just wants to descend with any mode like loiter, rtl, alt-hold. The only way to recover is to switch to stable. Is there some parameter that I could have changed by mistake? This copter was normally solid but since I fly in stable 99% of the time, I didn't notice when this started. Normally it held alt and position really well. GPS is on mast. Thanks! http://diydrones.com/forum/topics/3-2-1-and-apm2-6-not-holding-alti...
