Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks for your answer.
I have these mounting pads and thought of switching to the orange latex foam. But as this didn't work for you, I am afraid it won't help in my situation either..
The two plate mounting solution is no option for me because i want the FC to sit between the sandwich plates and there is not enough space for this mount.
I may have to test my motors maybe, as I already balanced my props.
@Dave,
I can help you with FFT analysis to discover resonant frequencies in your
vibration patterns to discover real cause  behind the vibrations.
Vibrations can be due to a number of parallel control data streams interacting each to other.
My fellow student lost his hearing, working as mainframe computer operator due to infrasounds generated by collective sound frequencies by individual mainframe colling system fans, damaging his inner ear mechanics.
So higher harmonics present in such sophisticated electronic gearbox -
processor's clock, PWM clock, flight controlle's clock, GPS clock ( 1Hz, 4Hz or 10 Hz), motor's RPM clock can make such to start generating much lower, infrasonic vibrations ( 1Hz - 30 Hz),
my next guess is moisture build up on platine connectors if you fly at higher altitude for a longer time
to keep stabilize mode to stabilize instabilities (see above) may eat up
100% processor power, make 100% memory busy,
so I would suggest to let Ardu fly your drone in debug mode and have
processor busy, memory free parameters downloaded via MAVLINK to your control station via telemetry.
darius
manta103g@gmail.com
Aargh this braindead forum software bit my post in half again..
The best of all I found was the original foam that comes with the pixhawk but it's difficult to find/get other than 3dr (which is not feasible outside of US).  If your X and Y vibes are OK then your motor/prop balance is probably OK so just try different density foam mounts and see if your Z vibes drop - at least below clipping levels as that's what seems to really upset the autopilot.  It's also worth looking to see if you have any bell play in the motors as that shows up with high Z vibes - see if you can find an excellent post on this subject by leonard if you can find it with this ridiculous antiquated forum software. If you'd missed it, I'm not a fan of this forum software.
ps - I wouldn't bother looking into ekf/gps or anything more complex until you've got vibes under control, so fundamental are they to stable level flight.  In hundreds and hundreds of flights with lots of different hardware with this awesome software I've only ever had unreliable behaviour due to vibes.
yeah, this software is a bit strange, I agree.
Okay, maybe I should try Moon Gel pads..
I will look into this and try to improve the z vibes before I fly the next time, thanks!
So what to do now to get the data for the FFT? Also, I think this would need a much higher sampling rate, doesn't it? I think its 50Hz standard, which is too low for high frequency vibes.
@Dave, an intelligent FFT analysis algorithm can self match sampling rate since samples can be approximated by continuous sinus/cosinus functions Infrasonic vibrations can be generated within very small cavities due to Helmholtz resonance (Holmholtz resonator)
longer reply has been already cut three times
just email me to get full reply
darius
manta103g@gmail.com
When connecting the SToRM32 gimbal controller via mavlink to the Pixhawk, getting parameters in MP doesn't work anymore. It just gets stuck on "getting params id 71". It is confirmed that more people have this issue. Firmware 0.89e, MP 1.3.33 and APM:C 3.3.2.
Bad days are coming....another multirotor failure....this time everyone will see it,world ski cup,no.1 skier escape for inches... https://www.youtube.com/watch?v=MvF49R_ZX5E ....what could go wrong?Marco Robustini,its in your country,do you know something about it?
Battery failure or ESC maybe. Operator faults: no safety distance, no parachute... that is not the proper way to promote professional use...
