Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Well for someone less experienced it would have likely ended crashing somewhere in the wild.
So yes, I would consider the incident serious.
Apologies, the f-ing forum software truncated my answer again..  I was also  trying to say that the term 'flyaway' seems to be used for circumstances where you lose complete control of the craft and nothing you do regains control.  There are lots of circumstances where it can behave unpredictably or erratically in various automated modes (toilet bowling, gps glitches, various recovery or failsafe actions, gcs bugs etc etc) but if you can flick it back into stabilise mode and regain control or into RTL and have it return, then from what (little) I understand then this isn't classed as a 'flyaway'.  In guided mode you're somewhat at the mercy of the GCS, although it's possible it's a bug in the guided mode itself.
It's an important distinction - phantoms are well known for proper flyaways where it's impossible to regain any kind of control, whereas it's extremely rare in APM (not bashing phantoms, just an example that comes to mind).
@Fnoop thanks for education. I am using FollowMe since its introduction extensively in my DIY stuff and with Solo, and know how it works.
Call it whatever you like, but having the drone speeding away when you hit Pause is not what you want.
@Randy thanks for having a look, if you need more data let me know.
Here is a short video about the incident
http://youtu.be/WGdAYg2UGJU
I wasn't trying to lecture you, just point out the fault might be with Tower not APM and it's not uncommon to hit glitches in the more complex modes.  Hopefully Randy can narrow it down from the log.
You may notice that Copter-3.3.3-rc1 is now available through the Mission Planner's beta firmware link.  It's a fairly minor change as you can see from the changes below (and Release Notes here) but any testing would be appreciated.
I must admit it got dark before I was able to test fly the exact firmware that the MP is dispensing but I will tomorrow morning and report back (I'm 99% sure it's fine but you might want to wait 15h just in case).
Changes from 3.3.2
1) Restrict mode changes in helicopter when rotor is not at speed
2) add ATC_ANGLE_BOOST param to allow disabling angle boost for all flight modes (requested by XCraft whose vehicle provides lift when leaned over)
3) add LightWare range finder support
Thank's Randy, any LightWare model is included? this is included?  http://www.lightware.co.za/shop/en/proximity-sensors/24-oslrf-01.html
fnoop dogggiee lost interest reading your comment past your name and first sentence. But i still did....
What Stephan is experiencing sounds very troubling. And you are not helping ANYONE with your comment. If you want to help try to reproduce this issue yourself with logs to see if more people see this issue and not just BLAH BLAH BLAH and BLAH
I don't think that oslrf you linked above will work because it's missing the analog and I2C interfaces.
By the way, the analog Lightware range finders were supported from Copter-3.3 but it's the I2C connection that's new with this release candidate.  Sorry, the release notes are not clear on that.
I've never personally used the Lightware rangefinders but Tridge really likes them and says they're very reliable.  From looking at the website I would go for the SF02 with the 50m range and $300 price.  That's not particularly cheap but that's what I'd go for if I were in the market.
I've test flown this this morning and it flew beautifully.  Thanks everyone for your help with the beta testing!
Stephen,
I didn't get to this today but tomorrow for sure!
Tried this today with fw 3.3.3 and tower app.
Just to make sure that I did everything the same way:
  1. Armed in stabilize and took off
  2. switched to pos hold
  3. switched to follow me in tower
  4. walked around with the drone following
  5. switched to pause in tower
The drone did what it shoud - it stopped in Loiter.
Did this error only happen when drone is armed via tower?
