Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
So, is that laser range finder take over all the function of barometer ?
Or, Light ware may be utilized for landing mode by the limitation of the range.
Thank you Randy for looking into this.
Please take all the time you need.
Btw it worked perfectly well with 3.2 and also no issues with Tower along with Solo.
A recent change on my end was to add a LidarLite via PWM.
warm regards
Stephan
That is just a warning about upgrading to that version and the need to re do the calibration. See Note 2 in red  in top post from Randy.
thanks Randy i was hoping you and your team were involved in it in some way and i could get a sneak peak earlier...ok i lied i wanna use those features NOW! :P thanks for the response Randy
thanks for the Response Bill but i think Randy answered this question succinctly enough! the feature really does alot more than just adding waypoints, which i was aware of.
aah, so thats means nothing to worry at all about that.. just redo calibration. thanks ^_^
I'm curious how these things work over water... can't find any documentation on that.  I emailed the company that makes the SFO2/2 about this waiting for a reply.
Randy
Do you know if the FrSky Taranis Telemetry will be supported in 3.4 so there will be no need for a teesny board just a direct connection to the smart port on the X8R rx?  I know there were people working on that. I think that would be a huge upgrade to the copter FW as it has become a very popular radio and adds a tremendous amount of info to the pilot without the use of a separate GCS. I would even go so far as to say it adds a great deal of safety  being as one can see the battery level and or get a warning when it gets low.. let alone all the other data it provides.
Richard, FrSky telemetry (both SmartPort and D series modes) came into support with v3.3. I was testing it just last week and it works OK. For X series Rx (I.e. those with smartport telemetry), you will need an inverter between the serial port of the taranis and the smartport of the X8R/X6R/X4R. There is a discussion on this very subject here: https://github.com/diydrones/ardupilot/issues/1587 plus details of how to build an inverter. I personally chose the  TTL-RS232 convertor plus diode method and bought a bunch off aliexpress. If you are in the UK, I'd be happy to send you the components for you to build one. This is basically the beastie (link from that same github conversation):
Here are the parts:
http://www.banggood.com/5Pcs-Serial-Port-Mini-RS232-To-TTL-Converte...
http://www.banggood.com/300pcs-2V-39V-30-Values-Zener-Diode-Assorte...
plus you will need a DF13 6 pin connector to connect to the serial port (I tested mine on Serial 4/5 port) plus the regular 3 pin servo connector for the X8R/X6R s.port end ( or the wee funky connector if you have the X4R).
The only thing really missing is a cool LUA script to give a really nice display of telemetry data. Because of this omission (and my lack of LUAbility ;-), I decided to stick with the Teensy 3.2 method of converting the Mavlink telemetry to FrSky S.Port and the LUA screens provided here:
https://github.com/Clooney82/MavLink_FrSkySPort
Works a charm! Good luck.
Thanks for all the info!! I thought the LUA script I had now would work but I guess not because it works with the teensy exclusively? One problem I'm finding is each time there is a copter FW update or a Taranis update it can screw up the Lua script and or not work well with the teensy FW so it's a lot of messing around to keep it working. I had thought once it works with the copter FW this would reduce or eliminate that issue... perhaps it will in the future? Thanks for the links I have them bookmarked!!!
Note their reply. I'll be buying one next summer! Good to know they have worked on the over the water issue!!
"Dear Rick,
We have a new unit that will launch officially in February, called an SF11/C.
This product has the best performance over water. We would not recommend the SF02/F.
It is very similar to the SF10/C, but with improved performance over water and a retail price of $249.
We will have stock during the next few days and are selling these to select customers already.
Let me know how else I can assist.
Kind regards,"
