Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
i tried to find some wiki pages about this... ...no chance...
Is there just no wiki page, or did i just not find it? ;)
Thanks  a lot!!!
I am using rc7. Mine is a quadcopter with 15" props. I am happy with the YAW responsiveness after autotune.
But is the following behaviour expected?
When I give a sudden full left-YAW command, the quad YAWs immediately but also climbs up for 1 meter and then returns back to its original altitude. When I suddenly release the YAW stick, the quad stops YAW immediately but also climbs up a bit and returns down again.
Here is a video showing this YAW behaviour.
https://www.youtube.com/watch?v=S4YkHe1Xq6U
I would like to upload a log here. But the log size is 350MB. Mission planner throws exception for "out-of-memory"!! If you need the log I can get it from SD card directly.
Thanks~~
I think that i2c LED has the same i2c address as your compass.
Johannes,
There's no wiki page for the alexmos setup yet I'm afraid although it's on the to-do list.
It could also be a power issue.  Maybe the flight controller doesn't have enough power for both devices.
My guess without seeing a log is that Copter needs to raise the throttle in order to give the demanded yaw control.  This is a feature of the "stability patch" where it needs to make a decision between attitude and altitude and it's choosing attitude (yaw in particular).  The vehicle has maximum attitude control available when flying at 50% throttle so one solution is to load up the vehicle with more weight so that it hovers closer to 50% (it must be hovering at less than that now).
A perhaps better software solution is to slow down the yaw response.  Leonard will know better but you could try reducing ATC_ACCEL_Y_MAX to reduce the maximum yaw acceleration.
Tests done. Success!
Two steps:
1) Buzzer disconnected. Battery failsafe worked, Iris landed smoothly. Log here: https://www.dropbox.com/s/hjuhqgtjzmt02ov/289.BIN?dl=0
2) Buzzer reconnected and moved from the top shell to the front of the main plate, this way:
failsafe worked as well. the log is here:
https://www.dropbox.com/s/33jdvhko1o5djso/292.BIN?dl=0
Thanks a lot Thorsten, Randy, Rob, and Leonard!
All is well, for now. But questions remain: why did this problem surface now?
Are the sensors defective and should I get the board replaced by 3DR?
Frederic,
Great news!  Maybe wires shifted within the case?
By the way, I noticed the IRIS doesn't look centered so I was going to send you a picture of mine, but mine's not centered either!  I'll email the RTF guys from 3DR.
Hi Randy,
I did the same double-take you did when I saw my picture above: Pixhawk not centered... I had never noticed before. That's its original position.
Thanks again.
I will try to reproduce it again. if logs do not show it, may be it was my own mental glitch, it is possible.
When I engage simple mode I always do small control inputs first to make sure I can control it and it goes where I expect it, in this case it was the same. then it just stopped going in the anticipated direction and I could not figure out how controls shifted, but, if logs do not show any errors, only way is to make sure again of what happened. I start from my driveway quite often, so, I will try again.
an operator error here could be if I actually moved myself, or turned 90 degrees after staying facing same direction when drone took off. it is probably possible, as I think of it now. unlikely, but possible. I will try again.
it is an amazing product, it is true, and truly unbelievable effort.
Thank you for your reply Randy. My quad should be indeed over-powered ;) Let me try ATC_ACCEL_Y_MAX and see if I can get a better altitude hold during YAW.
btw, do you have any tips on how to handle big dataflash log? My mission planner just halts when try to graph one variable.
The bin file has 350MB and txt file has 7xxMB.
I "cat" the txt file in cygwin and see there are many ACC1/2 and GYR1/2 records. Do these come from the temporary "400Hz" logging? my log level is "nearlyAll-AC315"
Many many thanks ^^
