Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I just saw Randy's post a few posts back mentioned using Ctrl-Q while in "Install Firmware" screen on MP. I tried it just now and now I can see "APM;Copter V3.4-dev Quad"  The pop up states these are the last trunked fws, so not sure if that's the same as a beta version or not.
I think there is often beta that although new has had some flight time by the devs but still not known to be %100 stable. When you do the Ctrl-Q you are installed 'bleeding edge' beta... it's less tested. It might have had changes that very day and not been tested as much as normal beta. If that makes sense.
Sorry my typo errors. I meant I only get v3.3.3 on stable or after I select beta. Just now I tried APM P2 advanced beta but I still only get 3.3.3 in both stable or beta. I would like to try beta 3.4 but not sure I am game to use the trunked version.   What version did you get ? Also what are the pros n cons between APM P2 and MP?
I have been running 3.4 dev without issue.  APM P2 and MP are very similar. I haven't used MP in a long time as my PC bit the big one but as I recall MP had a few more options. I have often seen post of screen dumps of reading logs and it seems like MP showed warnings or errors in the log I haven't been able to duplicate in APM P2 although it might be user error on my part.
Also... I recall just recently Randy mentioned sometimes it might say one version you are installing but it's actually the newer version. Sometimes MP or APM P2 hasn't been updated as fast as the dev copter firmware so it shows the wrong version however if you look at the message screen while your controller is booting up you can see what version you actually installed. BTW the only reason I have been flying 3.4 is because it has boat mode aka it will arm even if it's moving a bit. I don't really recall what other features 3.4 has.
hi randy, i don't see any amp copter 3.4 in mp and apm 2 ? i have install update mp and apm2.
AFAIK, the 3.4 is not in beta phase yet.
That's why it isn't showing in beta releases.
You can use the 3.4 dev with Ctrl-Q in MP and test it but as it is still changed by the devs, you could get a stable version on day and a buggy one on the other, so use it on your own risk.
Curious if you are testing the auto deploy while flying or on the ground? Looking through the code, it appears the parachute won't deploy if the telem reports landed=true, in the c++ source "if (ap.land_complete)",
It also records the barometer readings, and skips the deployment if the readings increase. I see a todo note in the code to check if its actually falling.
I wonder if the barometer check is the source of your issue. Watching the barometer on several of my pixhawks, the readings fluctuate. Maybe "random noise" from the barometer is affecting the performance?
Testing on the ground, so good point about the barometer.
I bought a new uBlox GPS unit from 3DR and replaced the cables to it, and started completely over setting up with the latest firmware and I am still getting these temporary deviances in perceived position. This is terrifying in that it is very dangerous to me and anyone around me. It also does this while flying missions, so when it recovers from its problems, it gives up on the mission it is running and decides to land, so now I can't rely on it for anything. I seriously think this is a problem with the Pixhawk. This is on a real Pixhawk from 3DR, that is a replacement for the one that had a known defect, but couldn't be replaced until after that one destroyed my quad. Fortunately, nobody was hurt in that one. This is just as dangerous. Can Randy or someone please look at my data and tell me if I am right? Suggesting that I buy more new equipment is not really what I'm looking for with this issue, either.
Do you have a camera or video equipment near? Can you share a photo how your gps is attached? perhaps that helps.
Here is a picture and you can see it up on the 3DR tower. I have used this configuration for a long time without this issue.
Has it flown successfully? I ask because I make it rule to keep the vtx antenna away from the GPS/compass and pointing down. That looks like a 1.3 ghz and could be wreaking havoc on them.
