Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
thank you for your comment.
Meanwhile, one hexa flipped over due to a very bumpy landing in RTL.
(No damages)
With 3.3.2  version, the copter landed always smooth and without jumping in RTL.
Now with v. 3.3.3 it bumps several times and also jumps sideways before coming to a stop.
We'll recalibrate now from scratch. Something is' t good.
What parameter should I change to soften the landing in RTL?
The final stage of landing speed is determined by LAND_SPEED parameter.
For the first stage of the RTL uses WPNAV_SPEED data.
By the way, we're going to separate the upper landing speed in Copter-3.4.  So there will be a LAND_SPEED_HIGH parameter added.  If this new param is left at zero (it's default) it will continue to use the WPNAV_SPEED_DN but if it's set to some other (non-zero) value it will be used.  This will allow people to set a much higher WPNAV_SPEED_DN without having to also having the top section of their land last be very fast.
So if it got set to LAND_SPEED_HIGH 5  AND WPNAV_SPEED_DN TO 1 it would descend faster at first then slow down to the slower decent or do I have that backwards?
Ok, so once it switched to Land mode (or RTL-land or Auto-Land) it would descend at 5m/s until it reached 10m above home and then after that it would descend at whatever LAND_SPEED is (by default it's 0.5 m/s).  If though during a mission the vehicle descended, it would descend at 1m/s.
Is it possible that the latest firmware reports things like "bad gyro health" more often?  Sounds funny, but I've been getting this message sometimes during flight or just hooked up to the computer making param changes.  No effect of flying so far.  I had two previous Pixhacks with this error, but they didn't clear and had to be returned.  One of the Pixhawks actually crashed.  I was under the impression it was definitely a hardware issue.  Should this autopilot be retired?  The message has shown up 3 times this week.
excellent idea!!!!
I am so pumped for 3.4......
I can confirm this. (often the bad gyro health 'report')
Randy,
The last time this occurred it was because of slow loops due to new code. Although not much has changed it is a recompile and some things have changed - I wonder whether this is a timing issue again and whether you need to adjust the loop timings.
That error can appear for a few reasons so it's hard to be sure but if it only appears soon after startup then I wouldn't worry too much.  If it's appearing in flight then I would worry and would probably replace the board.  Looking at a dataflash log and checking the IMU messages's final two fields (AccHl, GyrHl I think) which have the accelerometer and gyro health would be good.  If it's changing between healthy and unhealthy or one of them is always unhealthy then it's most likely a hardware issue.
ok, thanks for your comment :)
Is it enough to have the LOG_BITMAPS = 958 to see that later in the dataflash log? (Pixhawk)
