Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Well, I can say I'm pretty sure it's the computer it's plugged into.  When on the radio or laptop, no warning.  The desktop's a octacore with a PSU that dims the lights.  Didn't even think about all the emf coming from that thing lol.  So I presume the mag graph is normal?  Thanks!
Also cheap USB cables can transfer EMF
No, 3.2.1 is the last for APM 2.5/2.6/2.8
For copter this is correct that 3.2.1 is the last version that will load on APM, but plane is different. I think AP 3.3 is the last that will load on APM
For plane, 3.4 is the last APM release.
But as this is the copter 3.3.beta thread I didn't think it mattered too much.
Hi, :)
we just upgraded two hexacopter from Copter 3.3.2 to 3.3.3 .
The first connection and flights shows different behaviour than with the former version.
1* Do we have to re- calibrate the Pixhawk's after this update??
Also it took very (!) long to make the AUTOTUNE procedure.
At a landing in manual mode the copter bumps slightly up and down a few times before coming to rest.
In RTL mode, a copter bounces very hard up and down.
2* What parameter makes this bouncing happen?
Another copter suddenly shows compass inconsistency (with disappeared with a compass re- calibration).
So.................... shoud we re- calibrate all again?
Thanks for some input regarding this questions :)
 Which parameter take the place of INAV_TC_Z in arducopter 3.3
Antonio,
I think it's EKF_ALT_NOISE.  I personally never change it but I think that's the one.
Yes, after any changes in software versions have to re-calibrate all sensors.
The changes in the firmware from Copter-3.3.2 to 3.3.3 are incredibly minor and really shouldn't affect flight performance.
I wouldn't expect the sensor calibration to make any difference and shouldn't be necessary.  Some versions require a re-calibration of some sensors (like Copter-3.2.1 -> Copter-3.3.x requires re-doing the compass) but it's not a general rule and certainly shouldn't be required for the Copter-3.3.2 -> 3.3.3 upgrade.
I had some issues with previous updates, but cannot be 100% sure if firmware only related....
Thanks for confirmation Randy, I searched and finally this morning I found it in other 3d
I have some problems of altitude loss
