Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
No, 3.2.1 is the last for APM 2.5/2.6/2.8
For copter this is correct that 3.2.1 is the last version that will load on APM, but plane is different. I think AP 3.3 is the last that will load on APM
For plane, 3.4 is the last APM release.
But as this is the copter 3.3.beta thread I didn't think it mattered too much.
Hi, :)
we just upgraded two hexacopter from Copter 3.3.2 to 3.3.3 .
The first connection and flights shows different behaviour than with the former version.
1* Do we have to re- calibrate the Pixhawk's after this update??
Also it took very (!) long to make the AUTOTUNE procedure.
At a landing in manual mode the copter bumps slightly up and down a few times before coming to rest.
In RTL mode, a copter bounces very hard up and down.
2* What parameter makes this bouncing happen?
Another copter suddenly shows compass inconsistency (with disappeared with a compass re- calibration).
So.................... shoud we re- calibrate all again?
Thanks for some input regarding this questions :)
 Which parameter take the place of INAV_TC_Z in arducopter 3.3
Antonio,
I think it's EKF_ALT_NOISE.  I personally never change it but I think that's the one.
Yes, after any changes in software versions have to re-calibrate all sensors.
The changes in the firmware from Copter-3.3.2 to 3.3.3 are incredibly minor and really shouldn't affect flight performance.
I wouldn't expect the sensor calibration to make any difference and shouldn't be necessary.  Some versions require a re-calibration of some sensors (like Copter-3.2.1 -> Copter-3.3.x requires re-doing the compass) but it's not a general rule and certainly shouldn't be required for the Copter-3.3.2 -> 3.3.3 upgrade.
I had some issues with previous updates, but cannot be 100% sure if firmware only related....
Thanks for confirmation Randy, I searched and finally this morning I found it in other 3d
I have some problems of altitude loss
thank you for your comment.
Meanwhile, one hexa flipped over due to a very bumpy landing in RTL.
(No damages)
With 3.3.2  version, the copter landed always smooth and without jumping in RTL.
Now with v. 3.3.3 it bumps several times and also jumps sideways before coming to a stop.
We'll recalibrate now from scratch. Something is' t good.
What parameter should I change to soften the landing in RTL?
The final stage of landing speed is determined by LAND_SPEED parameter.
For the first stage of the RTL uses WPNAV_SPEED data.
