Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Raviv,
Are you using the I2C interface or one of the other options (analog, serial)?
If it's I2C then that's only available with Copter-3.3.3 (which is out now).
Hi Randy,
Thanks for the reply!
I used the serial port.
  • SERIAL4_PROTOCOL=9
  • SERIAL4_BAUD=19200
  • RNGFND_TYPE=8 (LightWareSerial)
  • RNGFND_SCALING=1
  • RNGFND_MIN_CM=5
  • RNGFND_MAX_CM=2500
  • RNGFND_GNDCLEAR = 15
Checked the Lightware with the analog and with a pc and works.
Just wanted to make sure its fully tested and if anyone else tried it yet.
Raviv
hi bro, what's Lightware ? using for ?
Flew my TBS Discovery with AC3.3.3, so far, it's stable :)
Hi Randy
and thank you for your grate work.
I installed the version 3.3.3 in pixhwak. Today i had a test flight.The GPS locked 11 sat bat after armed and the copter was in the air I lost the gps and the copter return to  failsafe land. I am trying  3 times with the same results.
Thank you in advance.
pixhwak 3dr
telemetry 3dr 433mhz
battery 16000mah.
gps m8n ublox
It is clear that you have bad GPS reception. It may be caused by GPS receiver low quality, bad cables or GPS jamming if it is close to a transmitter.
Do you have the GPS on long pole above the radios and the FPV transmitter?
With 3.3.2 or 3.2.1 I didn't have the same problem.
No gps problem until armed and after 1 minute flight.
The cabling is not very good. It is better to have them tighten together to the platform, not spread in the air. Use braided shields to have proper cable runs.
To protect the GPS from the inferences can use aluminum foil glued below the GPS body(all the black lower body.
Hello,
Anyone know what .cpp file has the hard coded rate P limits? Or is this done in Missionplanner? Looking to try lowering the p limit to .06
Hi everybody. I happened to install the Copter 3.3.3 on my Octa-Quad where I was flying the 3.4-dev of January 27th. The system turned to have a poor heading hold (oscillations of even 20 deg) and a poor position hold. I thought It might be due to a magnetometer calibration (as I moved the GPS on the back), so I calibrate it again, but same behaviour. In order to stop the oscillations in LOITER I had to increase the POS_XY_P from 1.5 to 2.5... Is there any major changes that are influencing that behavior?
I am about to upload the previous firmware and to make other flying test, maybe I could upload a set of telemetry that might be helpful for finding any possible issue
This is a capture of the Heading vs Desired Heading. It happen to get worst in Guided mode
