Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Tags:
I have a couple of issues which I can't figure out.
1. At the field the last couple of times I have not been able to get a 3D GPS fix at all. HDOP stays at 99. Now I'm in my office and I'm getting a 3D fix inside easily, which seems crazy. The only differences are I just upgraded to 3.3.3 from 3.3.2rc, it's warmer in my office than outside (by about 20o) and I am on USB power rather than battery. can't really see how any of these would translate into GPS no workee. Any ideas? It's not a connection issue in case anyone wants to suggest that :)
2. I have calibrated the accelerometers multiple times but I end up with a corner drooping in flight and the copter drifting a lot in AltHold. Could this be temp related? How flat does the mounting of the FC have to be relative to the frame? I would have thought that the calibration and leveling would take care of any discrepencies, but does it?
AUAV-X2 if it matters.
Andy, I see similar things, were it boots up fine, but will not lock GPS until I unplug it and start over. Then it works fine. Have you tried that? As for the leveling, that is done when you arm it. Whatever angle it is when you arm is what it considers level. Calibration, it seems is affected by the temp. I was having problems with accel and magnetometer cals and it was suggested that I cal in the cold. That seems to help, though it isn't as cold out now. Hope that helps.
I tried many reboots and change of batteries - same result. It definitely coincided with my upgrade to 3.3.2rc, but now is gone again. I guess I'll have more concrete proof if its now fine at the field.
I'd be surprised if level was set at arming - that can't be level at all!
Derek,
The limits are enforced by the mission planner but only on the extended tuning screen. If you adjust them using the full parameter list (or full parameter tree) screen then it's possible to set them to whatever you like.
If it's a heading hold problem then adjusting the yaw parameters is more likely to help. So for example, on the Extended Tuning screen (of mission planner), the Stabilize Yaw, and Rate Yaw parameters.
The compass's effect on the heading is quite slow, it's really most the Z-axis gyro that controls the heading so it makes sense that re-calibrating the compass didn't help much.
Hi Randy
I had a crash today.After the first flight (about 17min) I decided to had another flight. The copter was in hover and just increased the throtle (In pos.hold mode about 3-4 meters from ground) with out any other input the copter leaned right and it fell to the ground like a rock.
Quadcopter
pixhwak with copter v.3.3.3
Fnoop,
Any advice setting up the Z1 Tiny 2 in APM Mission Planner? What gimbal type do you select? (I assumed servo since that's the type of input that the tiny 2 would accept from a normal receiver). For whatever reason when I try to connect the input pins for the Z1 Tiny 2 to my Autopilot (driven by ppm from receiver) it just buzzes and doesn't care about what inputs I'm giving from my radio. If plug it in directly to the receiver it behaves like it should (slews to where I have my radio set to).
Thanks in advance,
Jeremy
Randy,when can we expect 3.4 in mission planer....is this thread dead or what(no post for 7 days),do i need to follow whats new somewhere else?
just had a look here: https://github.com/diydrones/ardupilot/milestones
The AC 3.4.0 milestone is only 27% complete. I guess now that a lot of developers have had their support withdrawn by 3DR the dev speed might be slowed down a lot. I'm not sure really what's going on. In the end it is an open source project and therefore has no real 'deadlines' to meet.
It is a shame, though. I was eagerly awaiting the EKF2 and boat take off. I tried flying master under controlled conditions and it worked great. But I'm too scared to fly master in the wide open.
I've been flying 3.4 since Dec without issue. Although if anythings been done since Dec I guess the experience could be different.
I'm not getting any Bata versions showing up on the MP after clicking "Beta firmwares" .
45 members
1472 members
282 members
470 members
57 members
Powered by
