Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
FWIW looking at your photo again, I have discovered that the cable end of LiPo batteries give off a lot of magentic interference and now mount my batteries with the cable end as far away from the compass as possible. I suspect you have enough distance for this not to matter, but FYI.
Sorry to barge in and this has probably been discusses a thousand times 'somewhere' but do you think it's advantageous to put copper foil tape on the bottom of a gps case? I have the typical black round plastic gps case on a mast. Would copper tape on the bottom be a good idea? Seems a but less messy that copper foil on all the wires. Thoughts? Thanks
I put cooper under gps on my last build, It's changed from 10-12 sats to 18-20 sats :O and I don't need a tall mast, only a second floor over the Pix, I connected the cooper to the pix with a ground wire.
So I've always been suspicious of this since I'm pretty sure every GPS has a ground plane anyway. I think the EMF interference is a field rather than unidirectional, so you'll be missing some of the radiation this way. That's why I think identifying the sources and shielding them is more effective.
But Cala's experience shows that it still works pretty well!
copper base helps a bit. but what helps way better is to use properly filtered 5V voltage feed, from a BEC separate from the one that feeds flight controller. when i rerouted power and stopped using 5V from the COM port where GPS was connected to quality of data has improved tremendously, as well as speed of sats lock.
I'm a bit confused lol.  Do you mean AcHlt and GyHlt?  If that's the one, I'm getting a drop from 1 to 0 on GyHlt from IMU2 every few flights.  Also, anyone know what this "ERR: 195-129" is?
hi randy and all friend.
My hexa is problem with speed up when  i push little thorttle up or down with YAW, then my drone speed up or down very fast, just alittle about 30cm.
My drone : 3DR pixhawk, 3dr gps lea6. KDE motor 475kv, esc 35A+. props 14.5, battery 6s 6.000mah, total weight almost 4kg.
ffrimware 3.3.3 i have try with autotune 3-4times but the pid look bad. can't fly with that pid. i have manual setup and it's look good abit, but with the post hold mode, when i push pitch or scroll and stop then my drone is oscillate, not smooth, but with loiter mode or alt hold work good.
Please give me an idea. Thanks all
this pids after autotune.
Pids are not bad, but stabilize pitch/roll params are usually not more 8. You can try manually 5; 6; 7 etc.
The reason for Yaw and throttle height variations is bad barometer ventilation. .Will be good to send picture of the copter and the Pixhawk position.
It is important to make the barometer damping with dense polyurethane, proposed by Marco and I posted here:
http://diydrones.com/forum/topics/upgrade-to-3-3-2-alt-hold-rising-...
Then should avoid the air stream from the propellers direct to the controller - can try kind of windshield, box with some side holes only or similar. When launching / landing the air pressure area below the copter can cause jumping, if barometer not damped.
Black Sheep (who I bought the pixhack from) says it interference...  Really?  Not the best answer.
Can't remember where I heard it or if its true, but something about the gyro does an internal calibration on power up and if the copter gets jostled during this time (like plugging in a xt60 main battery connector) it can throw this error. This would be different than the flashing red/blue partway through the pixhawk boot. Again not sure if accurate, maybe someone with the hardware knowledge can chime in.
Hi I need help with my Hexa on AutoTune
Hexa with 3.3.3 fly ok with default params no issue.
wanted to have smooth settings and done Autotune.
After Autotune is done and params are saved, Hexa Oscillates even on ground when arming and bit THR up.
Tried this twise by resetting all and running another Autotune, but with same results.
Can someone please help ?
did u run autotune and connect with telemetry and pc when autotune ?
