Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi I need help with my Hexa on AutoTune
Hexa with 3.3.3 fly ok with default params no issue.
wanted to have smooth settings and done Autotune.
After Autotune is done and params are saved, Hexa Oscillates even on ground when arming and bit THR up.
Tried this twise by resetting all and running another Autotune, but with same results.
Can someone please help ?
did u run autotune and connect with telemetry and pc when autotune ?
I run autotune and connect with telemetry to my phone running tower for monitoring.
log files
Autotune is not the perfect tool, it depends on the wind, vibrations, type of frame, etc.
My best experience with different frames is manual tune by tethering and in flight with the Ch6 manual tune tool.
It worked before with same setup on Copter 3.1
I don't have earlier pids but will test it maybe without yaw.
I had a look on your log from November 26, 2015
Is that same copter? PIDs seems OK, reacting quite well. It was overpowered at that log, powerful, but without load.
It is not good idea to tune large platform without the weight that is designed for. Can use dummy weight.
Last log shows huge oscillations, caused by wrong PIDs. The autotune gives bad results, probably due to the overpowered copter  - average ThrOut is 350.
Can you advice what is the frame, details, photos?
I can propose to test the following parameters:
Stabilize Roll 8, Stabilize Pitch 6, Stabilize Yaw 4.5
Keep the Rate Roll and Pitch PIDs from the last autotune.
Put Rate Roll/Pitch both Imax 1000,
Rate Yaw P 0.2; I 0.02; D 0
Since the latest version 3.3.3 I have a new problem with my hexacopter.
i'll try to explain, I take off in stabilize mode and try to pass to a constant hover, while doing this, the copter increasingly becomes uncontrollable and starts to rise also if i'm take away throttle. Depending on how the wind influences are, it takes a while until the copter really reduces the speed. like a delay. During this happens the copter is not pilotable and becomes unstable.i already had some crashes because of this so i'm just try to understand whats wrong, is this a known issue of 3.3.3 ?
it is a F550 Hexa Chassis for the prupose of Acro flying it's very overpowered. i need to set throttle mid to about 200 so you can imagine what power this thing has.i'm little bit scared and hope we can sort this out.
I have 3.3.3 on my F550 (replica from HK) frame and have none of the issues you describe. Saying this, my motor setup is a little under powered. By the sound of yours, I'd say its producing far too much thrust, especially for the F550 hexacopter frame which are inherently a bit on the flexible side. I have a few multi-rotors running 3.3.3 (and 3.4dev  on one of them) and all of these fly beautifully on 3.3.3 - really dialled in - but I did pay a lot of attention to balance, vibration reduction and good layout design. Like I say, in your case, without more information, my guess would say that its likely due to the combination of the frame flexibility and the overpowered motor/prop setup, which is likely inducing flex and twist into the arms (possibly oscillations) and hence vibration to be picked up by the IMUs which are probably having a tough time to produce accurate measurements, and hence inaccurate info for the FC to go on. In the 3.3 versions of Arducopter there are additional monitoring tools in Mission Planner for checking for any EKF issues, and also vibration monitors - all handy in checking for sensor and vibration issues. Also worth checking how the pixhawk is mounted on the frame - needs to reduce vibration without being too soft to allow the pixhawk to move around on its mount - which would cause false IMU measurements. Finally, check motors and props for vibrations and balance these as best as possible. My best guess though is that the exsessive thrust which is causing most of the issues. For this, you need to reduce thrust - maybe smaller props, or less LiPo cells to reduce the voltage/motor speed. If you want a really powerful copter then you need a very stiff and well balanced setup with minimal vibration. I have a 330mm quad based on Turnigy Talon v2 frame which is very powerful, and that's at the limits of the frame's capabilities and my mid throttle is 300 - yours is even more powerful on a far more flexible frame. For a more accurate analysis you really need to attach a log file. The guys in here are genius at analysing logs so probably your best bet for a more accurate response. Best of luck, Paul
Hi Guys
Is it possible to disable the announcing of the PX4v2 serial number when booting up / connecting to MP But keeping the other announcements still audible ? Its very annoying ..LOl
Regards R
That's very over-powered so with that low a hover throttle, there's very little room for attitude control.
A few things that may help:
1. lower THR_MIN if possible.  You don't want it so low that the motors stop (especially when the battery voltage is getting low) but lower than the default (130) should be possible and will give more room for the controllers to function.
2. increase MOT_THR_MIX_MAX from 0.5 to 0.7 or maybe even 0.9.  This will allow the controllers to increase the overall throttle in order to maintain attitude control (0.9 will allow overall throttle to climb to 90% of THR_MID).  Need to be careful about this setting though because if you set the THR_MID above the vehicle's actual hover throttle then you might have some periods where the vehicle rises even with the pilot's input throttle near zero because the controllers feel they need to raise the throttle in order to keep the vehicle upright.
Yes.
I use the little black knob.
Works fine ;)
