Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It was a Whitespy compass that I had trouble getting the orientation right with also. It is the only compass that I have used so far that required extra work to get it right.
Nothing strange in the log except the failing Loiter.
MR tries to correct position, but flies in the wrong direction.
The GPS quality (NSAT/HDOP) is not as it should be with a M8N. Only 9 Sats all the Time.
Perhaps you can try to configure GPS.
Sounds like it either has the wrong antenna installed or it is only reading the GPS sats and not GPS+Glonass
But yah other than that the logs look pretty good. Vibs are decent. Voltage is decent.
Thanks guys for the help on this.
Any website with a listing of the meanings behind the ublox uncenter parameters? I successfully connect to uncenter on this gps but I remember trying to upload that config file to a m8n gps last year and it bricked it and ended up buying a new one (current one). Still have the old gps but it didn't seem to respond after uploading the file.
That's one thing I REALLY like about Tower is if you select a param it actually tells you things about it. My GCS on my computer running APM P2 often just tells you you can select 0-10 or something like that for flight modes. So unless you have that memorized you don't know what to select.
i suspect all whitespy units are unsafe. 45mm gps unit ate battery i soldered in in fall over winter, and its gps is producing highly erratic data that causes vehicle to wander around. it is not charging battery and i am not going to solder in a replacement anymore. reading of sats also dropped from 18-20 down to 8-11, it correlates to responses from some other people. smaller 35mm unit seems to be getting more stable readings - vehicle is not hunting around that much with it as gps source but it is also reading 12-14 sats top, a m8n unit.
Didnt find correct place to post log related to 3.4-rc1
I am having serious issues with my copter, in the way that it does fly for a short period and then just descends abruptly hitting the ground. As soon as I see it descending (usually i'm flying at 2~3m above ground because I'm trying to find the cause of this problem) I switch to stabilize and cut throttle to avoid major damage.
At first I thought this is was a temperature related issue, but now I dont think so.
I saw a log that contained barometer error in the exact moment the temperature rised to 70º degree inside the frame (it's an waterproof one) but now logs dont even show any error, the copter just falls to the ground...
Anyone willing to help me figure this out ?
Copter 3.4 beta testing should be discussed in the new forum: http://discuss.ardupilot.org/c/arducopter/copter34
thank you :)
Test ......................
